Need maxine to start HELP....
Old Dec 31, 2005 | 05:35 AM
joe4's Avatar
hi org its been a long time. i am no longer a maxim owner but i did sell the max to a family member that is now having problems.when i had the car, it used to cut off at random or start bucking when i turn corners.it'll start right back up after it cut off.since he has had the car, the car was doing the same thing ,then one day it cut off but would not start back up. changed the fuel pump at random and it fired right up. now it started bucking again and cut off, but it wont start again. we pulled the fuel filter to check for gas and its squirting out at full blast.its a 92 ve. please give me some leads. the coilpacks that had cracks were wrapped with electrical tape. i thinking the car has no spark at all, but can you all point me in the right direction. thanks.
Old Dec 31, 2005 | 06:05 AM
Cliff Clavin's Avatar
Way out West
did you check the ECU for codes?
look in the stickies and there is information about the various codes.
to check the ECU, turn the key to the "ON" position. Then turn the little screw on the ECU clockwise, wait for 2 seconds, then turn it back counter clockwise . Then the red light will flash in 2 sequences. Slow flashes indicate the first digit of the number, Fast flashes will indicate the 2nd digit of the number. Say it goes "flash....flash....flash...........flash.flash.fla sh....." That would be a code 33 which is o2 senor. If there are no codes in the ECU it would read 55. Turn the screw counter clockwise, hold it then turn it back to the original position. (cut and pasted from that thread)
Without having a code, it is tough to say what it is. Sometims problems won't even throw a code.
Old Dec 31, 2005 | 06:57 AM
Greeny's Avatar
¯\(°_o)/¯
I think bhunter had a similar problem with one of his maximas....I think the problem was one of the relays under the hood was bad,causing it to cut out when turning corners....
Old Dec 31, 2005 | 08:33 AM
nismosleeper's Avatar
Fuel pump relay under the hood...I have had a similar problem.
Old Dec 31, 2005 | 08:52 AM
JRS89MAX's Avatar
Could this code check be done to a 89 max?
Old Dec 31, 2005 | 09:00 AM
Yes you can check the ecu which is under your radio and ash tray.
Old Dec 31, 2005 | 09:02 AM
Greeny's Avatar
¯\(°_o)/¯
the fuel pump relay is in the trunk area....
Old Dec 31, 2005 | 09:08 AM
Thanks for the clarification...the faulty relay was under the hood...I guess it wasn't the fp relay...
Old Dec 31, 2005 | 12:08 PM
joe4's Avatar
if the fuel pump relay was bad, would it shoot gas at all during starting, because the car is shooting
Old Dec 31, 2005 | 08:17 PM
HONKER24's Avatar
I had a similar problem with my '89 Max and it ended up being a corroded battery cable end. It happened at random due to the fact that the cable had to shift a certain way to lose contact with the positive battery post. It was hard to pinpoint because of that.
Old Jan 2, 2006 | 12:04 PM
joe4's Avatar
car still not started, someone help.i might try to buy the car back for myself
97_GXE
Sep 15, 2015 06:47 AM
QueensMAX
Sep 15, 2015 04:14 AM
trungg86
Sep 4, 2015 04:58 AM
