Car will idle fine but when it goes into drive it dies.
Old Jan 9, 2006 | 02:21 PM
Prophecy1's Avatar
Anybody have any ideas why this 3rd gen does this?
Just had work on the car to have a fuel injector repaired however it still doesnt drive right. The idle is erratic and it dies when ever switched in to drive.
Old Jan 9, 2006 | 03:46 PM
subs1000w's Avatar
if you give it alittle gas while you shift into drive does it still die or will it die no matter what
if it will drive fine if you give it some gas just bumb the idel up to around 1500and forget about it
Old Jan 9, 2006 | 04:31 PM
internetautomar's Avatar
mod or sell?
2thoughts:
1. IAC
2. Vaccum leak
Old Jan 9, 2006 | 04:35 PM
Greeny's Avatar
¯\(°_o)/¯
2thoughts:
1. IAC
2. Vaccum leak
I'll take vacuum leak for fi dolla alex...
Old Jan 9, 2006 | 04:38 PM
eric93SE's Avatar
check the MAFS connector.
Old Jan 10, 2006 | 06:07 PM
Roo's Avatar
Roo
my car had the same problem...
it was the MAS... unplug it, turn the car on and see if it runs fine then...
(it will run fine but will not rev over 2k rpm)
luckly my 300zxtt has the same MAS so i 'borrowed' it to get me through winter.
-roo
Old Jan 10, 2006 | 06:43 PM
subs1000w's Avatar
-roo
just so you know the 300zx maf is not the same electronicly but it is the same size im supprized your car ran fine with it
Old Jan 10, 2006 | 06:51 PM
vansskaterfreek's Avatar
i cleaned my IACV and it was fine after that.. i was having the same problem
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
doobadoo
Aug 15, 2015 06:43 PM
acw
Aug 7, 2015 04:20 PM
