strut spring
Old Jan 12, 2006 | 08:31 AM
magicdonjohn's Avatar
strut spring
the other week i noticed that my strut spring had slid over, like it was about to come off. i took it off and put it back on correct and now it seems as if its moving again. can anyone help me with this before my car fall over while driving down the highway. thanx a million. also when i turn i can here it. its not the drive axel. thanx guys
Old Jan 12, 2006 | 08:43 AM
Yicco's Avatar
you strut assembly needs to be rebuilt. you should not be able to just take off the spring. there should be a lot of compression on the spring, and if not your spring is sagged and needs replacement. check the top spring mount and the lower spring mount, make sure nothing is bent on the mounts. then reply
Old Jan 12, 2006 | 09:12 AM
Greeny's Avatar
¯\(°_o)/¯
Rebuilt?????
You need to replace the struts,springs,strut mounts,both sides..
Old Jan 12, 2006 | 09:21 AM
Yicco's Avatar
Originally Posted by MyGreenMax94
Rebuilt?????
the strut assembly includes: struts, springs, mounts(upper and lower). by rebuilt i mean he needs to replace the struts and re compress the springs.
Old Jan 12, 2006 | 10:46 AM
Greeny's Avatar
¯\(°_o)/¯
The lower mount is part of the strut...It can't be replaced unless you replace the whole strut...
Old Jan 12, 2006 | 11:12 AM
Yicco's Avatar
I thought they were cartridges... oh well.
replace
Old Jan 12, 2006 | 11:28 AM
internetautomar's Avatar
mod or sell?
go ask at any parts place for a strut assembly and tell me what you get
Old Jan 12, 2006 | 11:45 AM
i had to rent the tool from a-zone to compress the spring to take it off. checked for worn parts but everything looked ok. also when i turn i can hear noise from that same side. the struts were rpled about 3 or 4 months ago
Old Jan 14, 2006 | 02:38 PM
DennisMik's Avatar
my guess is that the spring did not get the ends seated in the notches and it is rotating. it may be coupled with the fact that whoever changed them threw away the plastic liners for the spring seats which will let the spring squeek and creep easier.
Old Jan 14, 2006 | 02:56 PM
cph81's Avatar
I have the lower spring mount and the top bearing. If you need it, I can give it to you for free. Just pay the shipping.
Old Jan 16, 2006 | 08:41 AM
im me and let me know the price
MaxLvr21
Oct 17, 2015 12:11 PM
maxima-junky
Oct 7, 2015 06:13 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
followthadollar
Sep 27, 2015 01:06 PM
