rear injector sub harness
I'm taking apart the engine to rebuild my VTC's and realized that the rear fuel injector sub harness is not in good shape. This is just a short harness running from the connector by the power valve activator under the plenum to the three rear injectors. I get significantly higher resistance for two of the injectors when testing through the harness, than when testing the injectors directly.
Any ideas where I could buy one of these? The subharnss can't cost much. It's about 18" long and I assume, being under the plenum, these get alot of heat wear and are replaced often. I tried Courtesy and they didn't have one.
I dont know if you like dealing with ebay but they have this.
http://cgi.ebay.com/ebaymotors/New-N...32417396QQrdZ1
Great, This is a big help. Thanks
Although the one in the picture on ebay is the earlier injector connector with the spring "c" clip holdon and not the one that I have for my '92 SE with the plastic squeeze tab to release the connector.
vingodine
45
May 21, 2016 12:46 PM
Finkle
Sep 27, 2015 09:53 PM
Huttig2009
Sep 25, 2015 03:31 PM
