VG Down for the count??
Old Jan 27, 2006 | 05:49 PM
Kimuel's Avatar
My college student son drives a 1991 Max SE 5-speed. Monday he drove it home for lunch and when he came back out, it started, but made awful top end knocking racket. It would not rev up and soon died. It can be restarted whenever I want, with the same results. I fear that we have slipped a timing belt. I bought the car last summer with the typical assurances about its repair history..... Since I have put in a new clutch, brakes, etc, I am reluctant to ditch it.
Any other thoughts about what may be up?
Also, has anyone ever recovered from a slipped/broken timing belt? I'd hate to go to the effort of replacing the timing belt just to find I have to replace the engine when I find bent valves.
I have access to a low mileage 1993 engine from a reputable friend of a friend for $250. What to do?? I haven't swapped an engine since a 1970 Mustang. How long for an old mechanic to swap the engine??
Sorry to be so long-winded and thanks for the help.
Kim
Old Jan 27, 2006 | 05:58 PM
Greeny's Avatar
¯\(°_o)/¯
I would aleast take the t-belt cover off and inspect the belt for missing teeth before swapping out the motor...But it does sound to me like a slipped belt though....
If you have swapped a motor before then then it will not be too hard for you...Just more wiring harnesses to plug back....
Old Jan 27, 2006 | 10:11 PM
DaWifey's90's Avatar
what can my max do for me
and if u decide to swap the motor in...i would do the timing belt and water pump while it's out of the car....otherwise u're looking a gift horse in the mouth and just asking for trouble - again
Old Jan 28, 2006 | 07:57 AM
DennisMik's Avatar
how mechicanically inclined are you? doing a front wheel drive is a heck of a lot different than rear wheel drive. go for it otherwise. just have a good service manual handy when you encounter something you're not sure about.
Old Jan 28, 2006 | 10:01 AM
Kimuel's Avatar
More news from this morning's tests:
The front cylinders have ~90 psi compression and the rears have ~160. I am inclined to change the timing belt and see...... I'll have to have one for the replacement engine anyway. It's just that this takes 4 hours of my life that may be for nothing......
Old Jan 28, 2006 | 11:36 AM
SurraTT's Avatar
HR Swap Pioneer
it takes 4 hours moving fast, it took me like 7-8 the
Old Jan 28, 2006 | 04:50 PM
internetautomar's Avatar
mod or sell?
just swap the motor.
if you have low compression then chances are there are bent valves
Old Jan 28, 2006 | 07:05 PM
MyBlue92Maxima's Avatar
ive got 125 psi to all of my cylenders,
Old Jan 29, 2006 | 11:58 AM
Kimuel's Avatar
For those of you that read this thread, here's the latest.
I managed to get everything disassembled to look at the timing belt. The tensioner was virtually non-existant. There was a bolt holding it on, surrounded by the surface the belt rides on, but NOTHING between. I tried to manually rotate the engine with the pulley bolt (to align the paint marks) and only the crankshaft turned, since the belt was so loose. I'm going to put a new belt and tensioner and check compression. Keep your fingers crossed.
Replace your tensioner when you replace your belt. My belt looks great, but a previous owner saved $35 and probably has cost me several hundred.
Old Jan 29, 2006 | 03:27 PM
goon9's Avatar
Old Jan 31, 2006 | 04:54 PM
Kimuel's Avatar
Last post:
I replaced the timing belt and tensioner. The car started right up and has 150+ compression on all cylinders. I'm on my way to buy a water pump and thermostat.
Rather be lucky than good.......
Old Jan 31, 2006 | 06:14 PM
Alex_V
you did get the front and rear heads the same cam timing right? One may not be a tooth advanced or retarted..
~Alex
Old Jan 31, 2006 | 07:19 PM
Kimuel's Avatar
I aligned all the marks....
MichaelAE
45
Jun 9, 2001 09:13 PM
Jeff91SE
18
May 30, 2001 10:35 PM
psing23
101
May 13, 2001 10:55 PM
Oiprocs
20
Mar 8, 2001 09:02 AM
Brandon90gxe
Feb 28, 2001 04:40 PM
