"interesting" trunk mod
Old Jan 28, 2006 | 02:17 AM
DaWifey's90's Avatar
what can my max do for me
http://cgi.ebay.com/ebaymotors/ws/eB...tem=8033861666
but what happens when u unexpectedly find urself loading something larger than the trunk and try to tie ur trunk down?
there goes any rear visibility....but insteresting still
Old Jan 28, 2006 | 05:48 AM
kcidmil's Avatar
Hmmm.... I had a friend who did it to his Grand Am. He kept having sealing problems up by the glass.
Though one thing did catch my eye, one of the smallest things there.
Product is covered
by warranty for as long as you own your vehicle.
Old Jan 28, 2006 | 06:25 AM
«§»Craig B«§»'s Avatar
you dont drive around with it open any more than you would with a normal opening trunk
The flip-flop trunk thing was pretty popular a couple years ago. I think Chris91se did it to his car, probably pics on his cardomain page
Old Jan 28, 2006 | 06:55 AM
really?!? it's not a downforce enhancer?!
lolol
i was refering to the visibility if u had to drive even with ur trunk just a little open...
Old Jan 28, 2006 | 07:50 AM
DennisMik's Avatar
a good while back someone had posted pictures on how to do this with door hinges and slide bolts you buy in a hardware store. all i have to say about doing this to you car is... WHY?
Old Jan 28, 2006 | 08:12 AM
lol..it's the jc whitney mentallity
Old Jan 28, 2006 | 08:55 AM
Phoenix's Avatar
Lives in a Maxima
they want $20? Hah... you can do the exact same thing with some little metal hinges from Home Depot and a little creative ingenuity... We did a mod like that on a Mirage for less than $5 and about a half an hour's work.
Old Jan 28, 2006 | 09:01 AM
KCMAXX's Avatar
KC's FINEST
The trunk dosent have to stay like that when its opened. It opens normally then you pull the front down level. Its only hinges
Old Jan 28, 2006 | 09:12 AM
Josh's Avatar
been there, done that, felt retarded, took it off.
Old Jan 29, 2006 | 12:46 AM
seenoz's Avatar
Trunk mod
What is this trunk mod for?
Old Jan 29, 2006 | 08:58 AM
Loco7's Avatar
It is a purly for show mods like that do draw alot of attention but are not practical for every day use. All you have to do is get 2 small hindges remove the top 2 bolts and screw in the hindgesit take a little bit of mesuring but still a easy mod. Than when you want to show it off you remove the bottom 2 bolts and you now have a flip flop trunk only hard part is bending the hindge at the right spot. Like this...
And here is what it looks like ona third gen max
Old Jan 29, 2006 | 09:51 AM
Jeff92se's Avatar
I'm needing a caw
How is it worse than a normal trunk open. That would 100% obcure your view
lolol
Old Jan 29, 2006 | 10:05 AM
Seb181's Avatar
That looks pretty sweet
Old Jan 29, 2006 | 10:39 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
been there done that like 4 years ago...
when trunk is not "flip flopped" it opens as normal
Old Jan 29, 2006 | 11:00 AM
SurraTT's Avatar
HR Swap Pioneer
it def stands out, but to ricey for me
Old Jan 30, 2006 | 01:07 AM
Loco7's Avatar
I agree but at show it does get you points and if you plan on showing your car like Chris91SE than yeah i say do it but if you have no intention of doing shows and stuff than I'd say don't bother.
I did a show last summer and as you can see my car if FAR from done but i got a lot of recognition for that MOD i didn't place but got a lot of compliments
AS far as the origanal question as long as you leave the bottom bolts it will only "FLOP" down when you take them out
Old Jan 30, 2006 | 02:46 AM
that's my point... this type of trunk really doesn't let u keep the trunk "a little opened" for carrying the occassional piece of lumber or whatever. a normal trunk u can tie down a bit and salvage some visibility...but with this mod it's really a matter of all or nothing.
Originally Posted by Chris91SE
WOW!! that is very very clean and tight
Old Jan 30, 2006 | 03:40 AM
SurraTT's Avatar
HR Swap Pioneer
it will still function both ways,
i think
Old Jan 30, 2006 | 06:30 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
like i said...when the trunk isn't "flip-flopped" it functions as a normal trunklid. if you need to tie it down for whatever reason you can. with this mod you lose no functionality of the trunk lid
thanks
Old Jan 30, 2006 | 06:35 AM
Michael's Avatar
Back in a 3rd Gen.
but it is functional as a regular trunk like the others in this thread have said it is.
study the picture and then think about how it works. Nothing can be in the way of the trunk (bottom edge under the reflector) in order for it to flip down. If you have something sticking out of the trunk a little and tie the trunk down you will sit the trunk (again lower edge below reflector) on that piece sticking out. If that is the case then there is no way to flip the trunk.
It is just a hinge on the trunk mounts and it opens and closes normally but when fully open you just flip it back. Some have used pins in them that will not allow it to flip if you dont want it to.
Old Feb 2, 2006 | 11:23 AM
Loco7's Avatar
as i mentioed in earlier post just leave in the lower bolts when you don't want it to FLIP FLOP and then when you want to remove them to FLIP FLOP it. otherwise if you don't have something in place it will not sit right when you close the trunk and water can leak in when it rains since it wouldn't be seating in right. which is why you have to have something to lock it in place so that you can lock it in it's stock postion otherwise it is a pain in the azz to close the trunk without it being locked in place
Old Feb 2, 2006 | 04:37 PM
Preach456's Avatar
that is a fly mod
Old Feb 2, 2006 | 08:53 PM
MyBlue92Maxima's Avatar
i actually tried it with some door hinges .. experimenting is bad. i couldn't get it to line up right , probally cause i didn't shave it down , the trunk didn't line up the the size of the hinges >.<
Old Feb 2, 2006 | 10:49 PM
Loco7's Avatar
the key if to do it with the trunk still on. you just remove the top 2 bolts than bend the small strap hindges with some carful mesurements screw down and there you go trunk is still aligned and if you bend the in the right spot trunk stays close to the bracket and you don't get too much rattle
Old Feb 2, 2006 | 10:53 PM
humm i took mine apart , if i have my car fixed up before the NY meet comming up i might bring some power tools and a bag full of hinges and make someone there help me out with it.
Old Feb 3, 2006 | 04:55 AM
Tampamaximus's Avatar
I bought that kit and will be installing it soon. I'll post pics on my cardomain site. For $20.00 I figure what the hell.
Old Feb 3, 2006 | 11:29 PM
Loco7's Avatar
yeah but for under $5 you could have just picked up the part at a local harware store
REDinLV
Aug 15, 2024 12:30 AM
REDinLV
Sep 28, 2015 12:31 AM
Sep 27, 2015 08:37 AM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
