Rear speaker deck
Old Feb 5, 2006 | 12:37 PM
goon9's Avatar
Rear speaker deck
I thought I'd give fleecing a try. Wasn't too hard.
The componets are cheap, but temp till all major construction is done.
10" sub, sealed in a wedge box. 6.5 mids.
Sounds pretty good too.
Old Feb 5, 2006 | 12:40 PM
max89_v6's Avatar
Wow! Now that's impressive. What kind of sub/midranges are you using?
Old Feb 5, 2006 | 12:41 PM
goon9's Avatar
Cheap ones. mtx blue sub, 'Dual' 6.5's
Old Feb 5, 2006 | 12:51 PM
AscendantMax's Avatar
looks good, any shots of the underside? is the sub free-aired?
Old Feb 5, 2006 | 01:08 PM
goon9's Avatar
There's not much to show, just a wedge box.
Oh yeah, forgot the mention, I had to cut out Alot of metal, lol. As usaul.
Old Feb 5, 2006 | 01:17 PM
ah i see, looks pretty good. one of the cleaner attempts of an rear deck spoiler i've seen on a 3rd gen
Old Feb 6, 2006 | 07:45 PM
DaWifey's90's Avatar
what can my max do for me
sweet and clean...i'd start taking orders if i were u
Old Feb 6, 2006 | 08:36 PM
oops...i meant rear deck subwoofer...
Old Feb 7, 2006 | 04:44 AM
MyBlue92Maxima's Avatar
very clean and if it takes up less space in the trunk that is sweet, realgoon..do you work as a mechanic or taken any like autoshop classes? whered you learn to do all the work on your car..or is it taken to a body shop
Old Feb 7, 2006 | 07:52 AM
jewsonlot's Avatar
very sweet. Are run fof the head unit or have got amps hiden els where?
Old Feb 7, 2006 | 08:49 AM
tripleGmax's Avatar
sweet you got it finished, it looks good.
Old Feb 7, 2006 | 01:48 PM
goon9's Avatar
Thanks everyone!
There was enough room betwean the back seat and box to fit the amp. I have a kenwood amp that open for cooling when needed, so i leave the arm rest down.
I worked as a mechaninc for 3 months, almost got knocked out by the mean red headed supervisor so I left, lol. But I enjoy toying with cars so I learn alot off forums and online stuff(rest is just common sense.) Oh, and I bug a few .org memebers for their wisdom, I won't list em so they don't get even more bothered, I'll to get more pics of the install.
One thing that botheres me a little, the box being a wedge and sealed has GREAT responce, full and clean. Till it suddenly distorts if I turn it up too loud, at that point it's just not wise anyway. If I knew more about proper porting I would of.
Old Feb 7, 2006 | 05:33 PM
porting it would require that box to be much bigger though. might be bit harder trying to hang a huge box under the rear deck.
Old Feb 10, 2006 | 03:35 PM
goon9's Avatar
Here's a few pics of how it was mounted/made.
Old Feb 11, 2006 | 03:32 AM
ur amp looks like it's insulated between the back of the rear seat and the speaker box....doesn't it build up a dangerous amount of heat?
Old Feb 11, 2006 | 03:37 PM
goon9's Avatar
No, the arm rest was gutted out, so it gets direct air flow.
Old Feb 11, 2006 | 05:36 PM
DMad8724's Avatar
would look sweeeeeeet covered in some suede or something! but looks good
what about the rear defroster vents? whats goin on with those
Old Feb 11, 2006 | 06:44 PM
silver91's Avatar
What rear defroster vents?
Old Feb 11, 2006 | 06:59 PM
goon9's Avatar
no vents, there not needed.
I'm really considering suede, but i donno where to even get it, stretch it, or how it'll even hold up to uv light, more research to do i quess.
Old Feb 11, 2006 | 07:12 PM
what's the internal air volume of that box?
Old Feb 11, 2006 | 07:38 PM
goon9's Avatar
1.2 cubic ft.
A sealed 10 needs 1-1.5 cubic ft.
Old Feb 11, 2006 | 07:42 PM
1 - 1.5 is a bit big for a ten. most 10s i've worked with requires .75 to 1.0 cu ft net. A large box wouldn't harm the sub, but reaching mechanical limit is rather easy (as you can tell when you have the volume up, and the sub starts to distort.)
Old Feb 11, 2006 | 07:45 PM
goon9's Avatar
Hmmmmm.... So If I drop the volume of the box it'll be able to play louder?
Old Feb 11, 2006 | 08:14 PM
possibly. the smaller air volume will act as a stiffer suspension on the cone of the sub. generally, a sub's power handling is inversely proportional to its box's volume. the larger the box, the less power a sub can handle. in a large box, the loose "spring" will enable the cone to reach mechanical limit sooner than compared to a smaller box. only tradeoff is that you'll lose a bit of lower bass reproduction, but nothing too drastic. but even in a small box, a sub can still distort when pushed.
Old Feb 14, 2006 | 08:29 AM
dadsmax's Avatar
Are those rear air vents just there to take up space? The defrog is thru the glass. Right or wrong.
Old Feb 14, 2006 | 08:33 AM
Greeny's Avatar
¯\(°_o)/¯
Now you need some tint to hide all that beautamous audio equipment....
No audio stickers ftl...
Old Feb 14, 2006 | 10:53 AM
maximapitko's Avatar
The Bulgarian Guy
nice idea and execution but it's not my style...good work though...
Old Feb 14, 2006 | 01:30 PM
goon9's Avatar
I'm just happy I have sound again, lol. But I'm not going to put in better compents till last. I donno wanna finish everything up with fugged up equipment from the reconstruction.
Door panels are next. Donno what I wanna do with them yet....
Old Feb 14, 2006 | 02:34 PM
Mr. Blue Sky's Avatar
impressive design work there. I kinda like to keep my 3rd brake light though
Old Feb 14, 2006 | 02:42 PM
Greeny's Avatar
¯\(°_o)/¯
Thegoon has the talent to put the 3rd brake light led's in the top of the trunk if he wanted too...
Old Feb 14, 2006 | 03:02 PM
Max93GXE's Avatar
Looks awesome, very clean in deed. I'm not sure if I would look into doing this to mine without tint since a lot more cars a getting broken into lately. About those vents I'm also intrested to know if they acualy blow air or not. I never really bothered to check..
Old Feb 14, 2006 | 05:54 PM
internetautomar's Avatar
mod or sell?
they are just pressure relief vents
matts95max
Apr 23, 2025 10:44 AM
9aj9
Apr 5, 2020 12:11 AM
bbsitum
Sep 11, 2015 04:55 PM
A32goldylocks
Sep 2, 2015 06:39 AM
