Dead power steering.. need help
Old Feb 6, 2006 | 05:05 PM
Maxzilla91's Avatar
Hey guys...
Symptoms:
No power steering at low speeds (no throttle input from stop)
Power steering goes back to "normal" once it gets up to speed.
Power steering fluid levels ok.
Power steering pump dead?? As I remember, the power steering hasn't been changed since i've taken ownership of the car over 2 years ago. Should I try changing the fluids first?
Old Feb 6, 2006 | 07:50 PM
DaWifey's90's Avatar
what can my max do for me
how would u rate steering effort at a stop while revving the motor (or at slow speeds with high rpm if u have a manual trans)?
sounds ike low system pressure which is either the pump or (hopefully) the belt just is worn and has too much slack .
check the belts
make sure the pulley is being driven correctly
if it isn't the belt then start saving for a pump..
per ur query 'bout the fluid, steering fluid (which is usually just auto trans fluid) rarely fails in such a way to cause ur symptoms
Old Feb 7, 2006 | 08:00 AM
jewsonlot's Avatar
i have similar problem with mine, first thing in the morning no power steering, its ok when the cars warmed up. going to change belt this weekend
Old Feb 7, 2006 | 06:57 PM
Maxzilla91's Avatar
check the belts
steering effort when the sympton shows up is 10/10... i'm talking absolutely no power assistance.
but with brute force, i am still able to drive the car.. so i'm thinking of leaving it the way it is and just save up for another car.
Thx for the help man... i really appreciate it.
Old Feb 7, 2006 | 07:20 PM
Greeny's Avatar
¯\(°_o)/¯
Replace your p/s pump dude...It has checked out...
Old Feb 7, 2006 | 08:41 PM
HoyaXC's Avatar
I'd make sure your belts are tight first before you replace your pump. It is an expensive repair and you will be kicking yourself if it was only your belt.
Old Feb 8, 2006 | 04:20 AM
most certainly
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
