Power Valve Control Solenoid Vacuum
Old Feb 8, 2006 | 08:22 PM
Travis92se's Avatar
Does anyone have a picture of the power valve control solenoid and the vacuum hose routing? If not, maybe some input on where the vacuum hoses come from that go to the solenoid. BTW, I have the FSM but it is not exactly clear as there are numerous vacuum hoses in the area.
Old Feb 9, 2006 | 05:03 AM
Greeny's Avatar
¯\(°_o)/¯
Here ya go..
The line that goes behind the intake manifold over to the power valve seloniod is metal..
Old Feb 9, 2006 | 05:20 AM
Travis92se's Avatar
Does the bottom line from behind the throttle body connect to the line with the one way valve to the surge tank (number 7 in pic. 3)?
Old Feb 9, 2006 | 05:28 AM
Greeny's Avatar
¯\(°_o)/¯
Edit: No it goes to the seloniod valve...
Old Feb 9, 2006 | 05:36 AM
Greeny's Avatar
¯\(°_o)/¯
ooops...I misread your post...No it does not go directly to the surge tank...
Old Feb 9, 2006 | 05:41 AM
Travis92se's Avatar
Thanks, its seems that I have my vacuum lines crossed or something. I previously had the solenoid but with an auto intake. I just bought a VI and trying to get all of the vacuum lines run. Where bottom line that exits behind the tb run then? I believe it is one of the the metal lines with a right angle shown in the previous pic. One goes straight to the egr solenoid I believe.
Old Feb 9, 2006 | 05:53 AM
Greeny's Avatar
¯\(°_o)/¯
If you mean this one,then it goes to the charcoal canister.I'm not sure if this is the one you mean??
Old Feb 9, 2006 | 06:01 AM
Travis92se's Avatar
Thats not it, but thanks for looking. I believe I see how it goes now. One more question, does the surge tank just work for the power valve? Because both lines on my auto intake run into the power valve solenoid, effectively doing nothing at all. Strange how it ended up that way but I guess they had to put them somewhere. I believe the surge tank should pick up vacuum from the manifold and send it the the power valve. Then the other line on the power valve solenoid run to the power valve. Things are starting to make sense. Thanks for you help.
Old Feb 9, 2006 | 06:11 AM
Greeny's Avatar
¯\(°_o)/¯
Old Feb 9, 2006 | 06:20 AM
Travis92se's Avatar
Thats the one. When I get home this evening I'll have to find out what is going to the fuel pressure regulator off of the auto intake. I'll have to get started on install this weekend and see how my 5sp likes having its vi back where it belongs. Awesome pics by the way.
Old Feb 9, 2006 | 06:25 AM
Greeny's Avatar
¯\(°_o)/¯
If you need a hand putting it all back together i will be glad to come down and help out...
Old Feb 9, 2006 | 08:29 AM
Jeff92se's Avatar
I'm needing a caw
You could probably mix those two up but it wouldn't matter. They are just pulling vaccum.
Travis, it looks like your intake arrived in good order. If you meet up with MySpleenMax94, tell him Stevie Wonder could weld better.
Originally Posted by MyGreenMax94
Old Feb 9, 2006 | 10:07 AM
Greeny's Avatar
¯\(°_o)/¯
I just forget to knock the slag off...
Old Feb 9, 2006 | 10:08 AM
Travis92se's Avatar
Yep, got the intake yesterday. I don't think it is going to be much of a problem to get it put on, I have had the auto plenum off a couple of times without a problem. I never noticed that the original power valve solenoid is still in place after all this time. That being said, it should be no problem to install as long as I can get the vacuum lines right and I think this thread has got me straightened out. Thanks for everything guys.
Old Feb 9, 2006 | 12:21 PM
Maxima Man's Avatar
Hi
I have a quick question what does the brown valve in the pictures above do/control ( Mine has a large nasty crack in the side of the rounded plastic pice and I am sure it is leaking Vacum so I just bypassed the valve with one pice of vacum hose.
What does it do?/whats it for?
What does bypassing do?
Anything harmful?
What do the black ***** do?
(I went over my one quick q limit!!)
Thanks Guys!!!!!!!!!!!!!!!!!!
Old Feb 9, 2006 | 01:41 PM
Travis92se's Avatar
That is the solenoid that send vacuum to the EGR valve. If you bypassed it then the EGR valve will always be open or closed (open, I think).
Old Feb 9, 2006 | 02:06 PM
Maxima Man's Avatar
What does that tell me what does that do to the exhaust ?
What will it effect? anything? any more comments answers
thanks!!!!!!!!!!!
Old Feb 9, 2006 | 02:30 PM
Travis92se's Avatar
EGR: Exhaust Gas Recirculation. It opens and closes constantly, (with the throttle I believe). If it is not functioning correctly it one thing that will happen is your idle will be screwed up. The solenoid is a necessary component or this system will cause you problems.
Old Feb 9, 2006 | 03:37 PM
internetautomar's Avatar
mod or sell?
when you're up here you can make me a CAI then I'll judge your welds
oh and hopefully you'll be able to see VE4
Old Feb 10, 2006 | 07:13 AM
Greeny's Avatar
¯\(°_o)/¯
Maybe by then it will be fixed...
Old Feb 10, 2006 | 08:23 AM
mod or sell?
it's only 2 injectors.
one of the guys will git R dun for me.
uncle doesn't mind because it won't be a rustbucket like VE3 was
though I now have a lead on 94VE (can't call it VE5 because that was VE2)
Starrider
Dec 18, 2015 04:43 AM
dcam0326
Sep 7, 2015 07:26 AM
03VQMAX
Sep 5, 2015 03:47 PM
