How to adjust idle speed with ECU ?
The sticker on the ecu says you can adjust the idle speed by turning the screw. What mode do you have to be in to be able to adjust the idle speed
with that screw on the ecu?
Any help is wanted Thanks!!!!!!!!!!!!
can't say i've ever seen such a sticker - then again can't say i've ever looked at my ecu.
in any case, i believe the screw they are speaking of is the one on the throttle.
idle speed is controlled by a number of factors. if u feel ur idle is off, it can very well be symptomatic of another issue.
There's an idle adjustment screw in the IACV (Idle Air Control Valve). It controls the amount of air at idle and then the ECU adds the right amount of fuel.
On my car (VE engine), it is located just under the Throttle body
Guys! on the ECU its self it says on a sticker that you can adjust the idle speed with the mode selection screw on the ecu.'
Don't you guys still have the gold/silver colored sticker on your ECU?
Come on somebody go out and have a look !!
Thanks!!
Thanks!!
to adjust the idle you turn that screw on the ecu as if you were going into diagnostics mode. you'll start to hear your iacv clicking and that's when you can turn the screw on the iacv to adjust the idle. when you get the idle where you want it put the ecu back into the normal mode and it should be set.
Thanks!!
Thanks!!
just read your service manual and see how it says to adjust the idle. ignore the stickers on the ECU.
Originally posted by Matt93SE
It may say that, but you can not adjust the idle on your ECU. I've seen the sticker, but I can tell you with 100% confidence that the idle is controlled by the IACV and the throttle stop screws..
Originally Posted by max89_v6
Technically, couldn't you adjust your idle speed high enough so (with a manual transmission), be able to release the clutch while in gear and not have to use any throttle to move the car??
KabirUTA13
19
Oct 17, 2015 02:15 AM
Andy29
Sep 29, 2015 05:32 AM
lux97Max
Sep 11, 2015 01:12 PM
ballerchris510
Sep 10, 2015 09:35 PM
