Factory Fog ?'s PLZ HELP!!!
My driver side fog went out and i bought a bulb to replace it but its not just a bulb ,it's in its on housing & im trying to take off the fog but there are about 6 diffrent screws down there does any one know which ones to remove to install the bulb
A. replace fog light bulbs
It's very simple for bulb replacement for your fog lights. The bulb you will need is model H-3.
1. Get under the bumber and look upward of the light housing, you will see a triangle shaped bracket that the housing is attached to.
2. On the side of the tire you will easily see a medium sized bolt. Remove this and then remove the similar bolt towards the inward of the car. The bold is the same size.
3. After both of these bolts are removed the light housing should come off.
4. Now turn it over so that the black side is up facing you. With a small-med phillips screwdriver remove both of the small silver screws. One screw on each side.
5. Now the backing is off, simply pull up the metal climp that holds the bulb in place.
6. Next, push back the little white flexible shaft (contains wires) pull bulbs wire out of connector.
7. Finally, replace with new bulb and but assembly back together.
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
