Rear defross amp draw
Old Feb 13, 2006 | 07:29 PM
jkmay01's Avatar
Lil 8
Not sure if this has been posted already? anybody have any problems when turning on rear defrost, that the current voltage on the battery drops extremely low? i live in a cold climate area, but even after drving the car for 10 to 15 minutes, i notice my voltage drops from 14.4v to like 12.7v. I have had the battery checked the voltage is good on it 14.4. I do understand by using the blower for heat and other accessories light headlights or fogs will cause more of a draw on battery. But let me know if anyone has come across this problem?
Old Feb 14, 2006 | 12:39 AM
Tom's Avatar
Tom
If you look on the corner of the rear glass in orange print, it reads 270W.
I assume this is for the power that the rear defroster uses. If that is the case, then 270W/14.4V = 18.75 amps. But since the voltage dips to 12.7 V, then it's pulling right around 21 amps. A lot, isn't it?
Old Feb 14, 2006 | 06:58 AM
jkmay01's Avatar
Lil 8
yea thanks for the imput, i thought so but just wanted another opinion,and yea!!! that is a large amperage pull for the rear defrost damn!!!! Guess i dont need to have to many accessories running while the rear defrost is on uh!!???
Old Feb 14, 2006 | 02:56 PM
Max93GXE's Avatar
I know the defroster uses a lot of power but like he said those numbers seem kinda high,,
Old Feb 14, 2006 | 06:08 PM
Trevmister1610's Avatar
i got the same problem with my rear defrost, with the car on and in park, i am at 14.4v, when i turn on the rear defrost i drop to 12.5v
Old Feb 15, 2006 | 10:37 AM
jkmay01's Avatar
Lil 8
yea dont know why it has so much of a draw, but it does, not too much that can be done other than dont turn on too much like big car audio set up, blower on high!!
Old Feb 15, 2006 | 05:47 PM
internetautomar's Avatar
mod or sell?
it's a large draw because of how a defroster works.
each one of those lines on the window is a wire that heats up (think what happens when you touch a postive and negative wire to each other)
that's a large amount of energy used which gives off heat
Old Feb 16, 2006 | 07:36 AM
jkmay01's Avatar
Lil 8
oh dont get me wrong i understand the concepts of electrical current and how the increased flow restriction of current causes the by product of heat. like a iron does, but ya lights in ya house dont drop like that!! lol i understand though just figure that a little less draw could be used to cause a heating action
Old Feb 16, 2006 | 05:40 PM
mod or sell?
well your house also isn't limited to 100 amps to run everything.
and some houses do have their lights dim when the heat/A/C first kicks in.
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
