Strange VE Problem
Old Feb 17, 2006 | 04:49 AM
geoff.doctor's Avatar
Strange VE Problem
I have searched, but have not found the answer. My VE A/T has a strange issue. I can be driving, and all of the sudden (usually when accellerating) the RPMs will drop to just over 1000 RPMs, jump up to about 1700 or so, and jump back down very quickly for a few secods. If I floor it or let off the gas it goes back to normal. Also sometimes the car will just die when driving or idleing.
The Fuel Pump sending unit was replaced 2 days after I bought the car. When putting it back together it did not start, and I noticed the fuse connectors under the dash were too far apart to make connection (I had a wire shoved in there because the fuse kept blowing, I know its unsafe and all), so I pushed them together and it seemed to work fine.
Also when I bought the car it had no O2 sensor. I put one in and thought it had fixed the low idle problem, but that seems to be back again this morning too.
Any ideas are appreciated. Sometimes this car is full of power, and sometime it just dies
Geoff
Old Feb 17, 2006 | 04:52 AM
MaxGordon7's Avatar
old cars have problems! :P
Old Feb 17, 2006 | 05:27 AM
Greeny's Avatar
¯\(°_o)/¯
Nice post flushgordon
Old Feb 17, 2006 | 05:29 AM
Greeny's Avatar
¯\(°_o)/¯
Geoff
Could be the mass air flow sensor is bad or needs a good cleaning..Also may be a bad coil pack or two....
You can clean the maf sensor with electrical contact cleaner...Very gently...
Old Feb 17, 2006 | 05:43 AM
maxitech's Avatar
The MAF is a good place to start, but there's probably something more to a problem that dramatic.
Old Feb 17, 2006 | 07:25 AM
internetautomar's Avatar
mod or sell?
sounds like the coil pack issue to me.
if you ever make it down here we can do some part swapping "diagnostics" with my spares and car
Old Feb 17, 2006 | 12:24 PM
Cliff Clavin's Avatar
Way out West
sounds like a pretty common "stalling/bucking" type problem that is due to faulty coil packs.
Mine had a bad rear one that caused that same thing.
Old Feb 17, 2006 | 01:49 PM
bhunter's Avatar
I second the motion of coil packs. Feels just like you let off the gas, right?
Old Feb 17, 2006 | 02:49 PM
subs1000w's Avatar
i third it
Old Feb 17, 2006 | 05:09 PM
Way out West
search in the 3rd gen section for stalling bucking or that + coil packs
There was a huge thread about this maybe a year or so ago. Honestly, Just change out coil packs.
One word of warning, though. You might just buy one each (front and rear) then swap them in and take the car out and see if it causes it. On mine, they all looked good and seemed fine at idle. It is when you put a heavy load on them that they crap out. Mine would do it a lot under WOT and accelerating on hills.
Old Feb 17, 2006 | 07:55 PM
Coil Packs it was I swapped them all out from ones from the 93 VE Parts car. Worked like a charm. I broke the MAF while trying to get it out, so I added another one of those too. Runs like a charm. None of the coilpacks seem cracked, is there an easy way to test them? I know not all 6 are bad.
Old Feb 17, 2006 | 09:00 PM
bhunter's Avatar
The only way I know is to put them in one at a time until the problem resurfaces. I couldn't tell on mine with a ohmeter. They don't seem to fail until they are stressed.
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
