Fuel problem
Old Feb 21, 2006 | 02:10 PM
92washingtonSE's Avatar
Fuel problem
Having a major problem with getting fuel into the fuel rail. Fuel pump work fine, and hoses are connected with no leaks. Any clues as to what else I should check. I check the fuel going into the fuel filter and there was fuel there, but when I check the fuel rail crossover pipe there isn't any fuel flowing into the pipe. Its an VE30de if that helps.
Old Feb 21, 2006 | 02:15 PM
Jeff92se's Avatar
I'm needing a caw
Hmm. You could try to disconnect the fuel line that goes into the filter and see if it sprays fuel when turning the ign to on. Careful when you do this!
Just because there is fuel in the filter might not mean there's fuel flowing. You could also try an inline fuel pressure guage. That actually might be a better idea.
If you think it's a clogged rail, I have an extra empty fuel rail for sale. And another rail that has the injectors installed.
Old Feb 21, 2006 | 03:26 PM
internetautomar's Avatar
mod or sell?
have you checked to see if fuel comes OUT of the filter?
Old Feb 21, 2006 | 04:50 PM
Fuel is spraying out of the hose when turning the ign on. going to try the inline fuel pressure gauge tomorrow. Any way to test the fuel pressure regulator?
Old Feb 21, 2006 | 06:37 PM
vansskaterfreek's Avatar
did you make sure fuel sprayed through the filter???
Old Feb 22, 2006 | 07:19 AM
Fuel is spraying through the filter, is there anything else I should check before I give up on trying the find the problem and have it taken into the shop?
Old Feb 22, 2006 | 09:45 AM
Jeff92se's Avatar
I'm needing a caw
From the back to front? Or front to rear? I "think" the fuel flows into the rear rail, crosses over to the front and then back to the tank. Take the plugs out. Are both front and rear banks of plugs dry?
Old Feb 22, 2006 | 07:32 PM
Front bank is dry, still have gas in the rear bank.
Old Feb 22, 2006 | 10:28 PM
Jeff92se's Avatar
I'm needing a caw
Well you're in luck. You might be able to pull the front rail w/o removing the intake manifold. But I'd check the x-over tube 1st.
http://www1.autozone.com/servlet/UiB...3d801f5163.jsp
I do have a spare injector rail (bare with no injectors if you need it)
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
bumpypickle
Sep 20, 2015 08:22 AM
aminus21
Sep 12, 2015 04:53 PM
conansriver
Sep 11, 2015 10:26 AM
