did an 8 hour axle job today.
my friend and i replaced the pass side axle on my vg today. on an inclined driveway. what a b!tch. we started around 10 and the car was back on the ground at 6. pulle the lower control arm apart by the 3 lower ball joint bolts. not the best idea. had to end up both of us under the car, one with a punch and the other with a hammer to get the old axle out of the carrier bearing. and then we had to raise up the other side of the front end to take weigth off the sway bar to get the ball joint back together. my friend is a honda guy and i had never done one of these axles before. so other than the axle cost there was a roll of shop towles a pizza a six pack and a 2packs of smokes added to the cost. but it was a fun day. just hpe i dont have to do it agian for a long time.
o and vans were u racin through pine hill today?
It seems like that is an awful long time.
I suck at teh mechanics, but I think in the two times I have been involved in taking out my transmission(s) the axle was about the least of the concerns.
The good news is, next time you will probably do it in half the time or less.
I did my driver side this past monday, luckily driver side is the short axle, had it done in about 1 hour cuz the axle wasnt poppin out of the tranny and plus my g/fs dad was somewhat buzzed so it slowed things down a bit, I'm glad I know how to change it now as he was tellin me how and what to do. How much harder is it to change the passenger side?
by the way we did the same method as Matt described, he said it would make things faster and it did, would've worked if he was a bit more sober and lighter outside
I can't believe that you guys do stuff like this in the driveway with jack stands. That is how my father was killed when I was four. I always use a lift. I know a lift is not available to everyone but getting under a car or truck on a jack or stands gives me the creeps.
newer jackstand designs are MUCH safer than the old stamped steel ones. The only time I've ever had a car fall off a stand was when it was a 20 yr old stamped steel one and my fat sister was leaning on the side of the car. other than that, I've never had an issue with working under a stand as long as the car is supported properly- even done engine and tranny swaps on a pretty steeply sloped driveway- just chock the wheels well and double check everything before you get under the car.
heh, nice. i dunno about that 30 minute comment though. maybe if you can pry that bearing joint apart easially, but i spent hours trying to get that damn axle out and finally gave up and just pulled the tranny from the axle which i should have just done in the first place. removing the passenger axle was easially the most difficult and stressful part of the input shaft bearing job and the kicker is you don't really even need to touch the rh suspension
why did you see me????? how far away do you live???when changing the passenger side axle, since the axle is bad anyways, you mind as well hit it out with something.... like a screwdriver or a small prybar.. makes things alot easier.. expecially if you dont need that old axle
I've changed many an axle on these cars and it usually takes me less than an hour for the pass side and about 10 min for driver side.
if the pass side is frozen in the carrier bearing, use a torch to heat the outer shell, and then whack the outside part with a hammer and try to turn it. Also have someone on the outside of the car giving it a few good pulls and it usually comes out in a matter of seconds.
im in bellmawr, i thought i saw u flyin through the intersection on erial rd where the wawa is at the top of the hill. and we did use a punch and a hammer to knock out the old axle from the carrier, but it was pretty well frozen in there
we had a stand under each side and a jack on each side the car was very stable. i do wish i had acess to a lift.
Im sure all of you have a blast with the seals. I know I did. That took most of the time on the axle job.
And about the jackstands failing.. I was wondering if that was possible everytime Im under there. Those things do fail, huh..
Anybody know if the "new" designs ever failed with proper support?
im sure ill be bashed for this, but i dont use jackstands, my car is too low and i dont have a tall enough jack.
I just jack it up
and get under lol
ive got an awesome jack, so im sure its not going to fail
Btw, whats the best way to get the axle out if its stuck and wont seperate from the tranny.
I just jack it up
and get under lol
I just jack it up
and get under lol
I just jack it up
and get under lol
btw no matter how low your car is you should have stands to back up the jack I dont care what kinda jack it is at least get them damn ramps for 12 bucks each.
I just jack it up
and get under lol
I just jack it up
and get under lol
[QUOTE=backNblackj30]im sure ill be bashed for this, but i dont use jackstands, my car is too low and i dont have a tall enough jack.
I just jack it up
and get under lol
I'm sure my father felt the same way. He died and left a wife and five kids.
I just jack it up
and get under lol
My car was lower than yours appears to be (Intrax) and I had no problem at all putting jack stands under it. It has nothing to do with the height of the car anyway...just on how high you can jack it up.
I am not going to flame you for not using jack stands at least but you never know what will happen. It wouldnt take much to rock the car off of the jack (pulling and rocking on stuff that is stuck) and then you have a 4000 lb car falling on you.
I would think your life is with the extra minute it takes to put the car on jack stands.
Of course you have to put them in the right place as well to be safe.
For the record I have seen EVERY manner of lifting a car fail.
whether it be a $350 snap on jack (seal failure) to a 2 post lift drop a car on it's side (pulley bolt sheared and the safety failed)
Yea, its not how low the car is, its how high you can lift with the jack. Now if you have such an awesome jack, simply keep the handle twisted clockwise and jack it up a couple more inches til you can fit a jack stand.
i know someone who was under just a jack, and when the car fell, somehting punctured his lung and almost died because he couldnt breathe..... or yell for help b\c of the lung..... stay smart man.. it dont matter how good your jack is, **** fails man!
but that is a better solution than a guy underneath there with a prybar and mallet. i got it about 1/2 way out and seemed to be completely stuck after that. at which point i said fck it. after removing the tranny, it took about 6 hard whacks to the butt of the axle to get it to break free. i'll be sure to get a torch and another person next time.j30-get some gad damned jackstands and enjoy your skull!
Help
My right side axle is stuck. Excatly what should I wack and where to knock it out. I tried a air hammer chisal between the mid way holding bracket and the axle. No luck... I have tried a 24 in pry bar between the braket and the holder still nothing. I comes out maybe a 16th inch then nothing.....
Help me
Help me
Originally Posted by terryg911
Help
Help me
Help me
Have you removed the center support bearing bolts????
try matt's suggestion. go grab a torch and burn it to bloody hell
oh wait, no heat it up and bang the knubs with a mallet and a long piece of something. i never heated mine up but from what's been said in this thread it works well.
Can you say dumb *** ......
Note to self remove all bolts before beating the hell out of it...
Well I removed two out of the three carrier bearing bolts and completely missed the third. Once that bolt was removed it came out easy peasy japanesy. With in another hour I was adding oil and I am off. I added Amsoil GL4 75-90 and the cold 1st and 2nd shift thing is almost gone. Way too cool and it is shifting really sweet.
Thanks for your help
Remember all three bolts
Glad you got it off. I had a battle with the same axle shaft. I took a pipe and a 5 pound sledge and beat one of the 'ears' on the bearing side until it rotated past the bracket. Then I could get a large screwdriver between the bearing and the bracket and pried out the axle. It is a tough job due to the lack of space under there so you can't really generate enough force with each swing of the mallet. I am not looking forward to that part of the job when I do the tranny swap next week. Thanks for the tip using the torch, I will give it a try if I run into trouble.
Originally Posted by VEvolution
I loved reaching the one thats hard to get to. I'd feel bad for a guy with fat hands.
Never wear your watch when working on your car either.
Originally Posted by Priority05
That reminds me of the time I was in the boneyard and got my hand stuck. Took me about 5min. to get myself outta that one.
