Stuck in 1st when cold!!
Old Mar 15, 2006 | 04:17 PM
hoyshnin's Avatar
Baby's on the Half Tip!
If my engine is cold and I start it up and shift into first, I'll let out the clutch and try to go and the car won't budge. It'll try to move, but it's like the brakes are on or something, and it's just trying to push forward but can't. Then I'll push in the clutch again, shift into neutral and back into first and everything is fine. What's happening?
BTW, I do know that my clutch fluid (DOT 3) was low awhile back and I filled it right back up and it's still full. I don't think fluid is a problem, I used some high quality DOT 3, so it's not cheapo brand or anything. Any ideas?
Thanks a ton guys, you rule!
Old Mar 15, 2006 | 04:23 PM
Greeny's Avatar
¯\(°_o)/¯
Mine does that too when cold....Nissan trannys ftl...
I figure it's probably a bad syncro....
Old Mar 15, 2006 | 04:51 PM
Alex_V
change or put in thinner fluid. When its cold out the fluid thickens and doenst lube up the shifter and gears egnough. My 240 and maxima do this.
~Alex
Old Mar 15, 2006 | 05:00 PM
internetautomar's Avatar
mod or sell?
go synthetic on the tranny's fluid.
Old Mar 15, 2006 | 06:49 PM
hoyshnin's Avatar
~Alex
What kind of fluid do you suggest? And I'm assuming you're talking about the DOT 3, right? Also, I am running full synthetic oil.
Old Mar 15, 2006 | 07:08 PM
Alex_V
No the oil in the tranny. I just run the napa generic GL4 stuff, but when I replace my pass. axle in the spring im swtiching to MT-90 or lucas oil. 75w-90. im not sure what my 240 takes though. Id like to know if its fluid has ever been changed...
~Alex
Old Mar 15, 2006 | 07:44 PM
subs1000w's Avatar
does it do it in rev also or just first
changing the fliud proboly wont fix this problem it sounds like its on 2 gears at once or something
Old Mar 15, 2006 | 07:59 PM
PovCityHustla's Avatar
Agreed, tranny service does soo much for the shifting. My auto was screwed till i got a tranny service
Old Mar 15, 2006 | 10:31 PM
hoyshnin's Avatar
No, it only does it in first, sometimes it takes a second to get into reverse when just starting up the engine, but I think that's typical when it's cold. The sticking in gear and not moving, though, is only in first.
How hard is it to change the tranny fluid by the way?
Old Mar 16, 2006 | 07:23 PM
vansskaterfreek's Avatar
there is a screw type thingy that you need to get a socket or a wrench on... it is on the drivers side near the front of the tranny, but the plug is facing the drivers side tire, not the front of the vehicle
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
