speaker ques
speaker ques
I made some speaker adapters for my old max and the speakers I had then I trial fit those at that time and they fit
well I've still got the adapters and I want to use them with the ininity reperence 6012i that I just got out of the eclipse, but I don't know if they'll clear the window and regulator.
anyone know the depth from the metal to the regulator?
I'd like to find out before I take the door panels off
well with my MDF adapter i used on my 3rd gen, total height of the mount was 1". a 3/4" MDF ring was glued to a 1/4" inch plate. and my speakers didn't have any issues clearing anything.
how tall are your adapters?
I ended up just slapping them in.
they clear just fine.
can't say the same for the rears though. I can't mount them :WTF:
the OE 6x9 bolt pattern is to small anyone have any suggestions?
Originally Posted by klown_phreak
When I put my new 6x9's in I pulled out the bracket in the trunk that holds the amp up to the rack. Gutted the amps out (blown amps) and mounted my 6x9's to the bottom of it. The bolts won't line up totally because of a plastic "tube" half way around each bolt, so I cut them off enough to get the speakers snug. So maybe this would be a good idea for you as well?
that may work.
how'd you get the brackets off?
crap, I guess I'll cut them while they're still in the car
Your best bet would be to remove the nuts from the bottom, pull off the old speaker, and then snap off the "tubes" and then try to line them up and put the nuts back on. Your biggest fight then should just be trying to line the bolts up.
I don't think I can snap the tubes as the bolts are in them and can't come out (at least not from how I can see)
I have Infiniti reference 6x9s and they went in easily in the stock location mounted from inside the trunk. I didn't take anything apart or take anything out, except the stock paper Bose speakers.
well unfortunately mine don't
http://www.infinitysystems.com/caraudio/product.aspx?ProdId='REF9613I'&Ser=REF&Cat=MEL
that's what I've got.
note that the holes are round rather than oval like OE and most aftermarket. the plastic spacer on the tp of the speaker also soen't appear to have enough space to clear the plastic pieces either. I know that the car I pulled them out of didn't use the stock holes either
magiconthetire
10-26-2015 09:03 PM
Kyle Lee Cleveland
09-28-2015 07:58 AM
maxfever1987
09-06-2015 06:20 PM
