lost my valve cover thread.......here's a question
Old Apr 2, 2006 | 01:13 AM
aw89maxSE's Avatar
do I have to take this off (red) to get to the valve the cover to replace gasket (green)? I am guessing yes and how hard is it?
I can see the oil its leaking burning from where the gasket is dead
Old Apr 2, 2006 | 03:36 AM
MrGone's Avatar
yes you will need to remove that, make sure you buy a new gasket before you remove it.
Old May 18, 2006 | 01:37 PM
aw89maxSE's Avatar
which ones?
http://www.partsamerica.com/ProductD...pe=107&ptset=A
I talked to the guy there amd he said if you see the steam/smoke coming from the outside near the edge of the gasket, I would probably just need the cheaper one
Old May 18, 2006 | 03:45 PM
Greeny's Avatar
¯\(°_o)/¯
I would get the one with the rubber grommets..The original ones may leak if you try to reuse them...
Master cylinder work ok???
Old May 18, 2006 | 04:22 PM
aw89maxSE's Avatar
even if I am only needing the outer gasket?
lol i got the master cylinder and put it on and while I was putting it on, I hit the piece that it fits over and I got air into the lines and so I havent had a chance to test it but I havent seen any leaking so thats a good sign
Old May 18, 2006 | 04:30 PM
Greeny's Avatar
¯\(°_o)/¯
Well if you want to be sure it is not going to leak,then go with the grommet set...Or you could go with gasket only set and HOPE it doesn't need the grommets replaced too..
Old May 18, 2006 | 04:36 PM
Matt93SE's Avatar
STFU n00b!
before you pull the intake manifold off, try using a #3 phillips and tightening the screws on the valve cover. often that's all it takes to stop the seepage and you can save yourself hours of work.
If not, ONLY BUY THOSE GASKETS FROM THE DEALER!!!!
I can't say it any simpler than that. you're guaranteed the right parts that way and you know the quality is good. You're looking at like $15, so it's not like you're going to get skrood by dealer prices.
Old May 19, 2006 | 06:40 AM
894DSC's Avatar
I thought the gaskets for the plenum were like 80.00 from the dealer ??
Is there somewhere else I can get FACTORY gaskets ?
I'm going to be doing the same procedure when I do the exhaust manifold bolts. I figure knock both out in a weekend after the transmission is replaced.
Troy.
Old May 19, 2006 | 10:07 AM
Matt93SE's Avatar
STFU n00b!
Part Number: 1403389E00 List Price Core Price Your Price
VG30E COLL/COLL $7.58 $0.00 $6.60
Part Number: 1403289E01 List Price Core Price Your Price
Fuel system - Fuel induction - Intake - Plenum gasket PLENUM GASKET, Stanza, SOHC 1991 - 1994 $9.95 $0.00 $8.66
Part Number: 1617589E00 List Price Core Price Your Price
GASKET-THROTTLE $6.20 $0.00 $5.39
Part Number: 1617589E10 List Price Core Price Your Price
GASKET $11.60 $0.00 $10.09
there ya go. part numbers and everything for a VG produced between 88 and 91.
that's all 4 intake manifold and throttle body gaskets, and if you're just changing valve cover gaskets, you only need two of them.
Old May 19, 2006 | 10:40 AM
JET_MMPro's Avatar
For something
Old May 19, 2006 | 11:18 AM
JET_MMPro's Avatar
If time is of the essence, I recommend going with the OEM gaskets from the dealer. It’s been my experience over the last two years that something changed in the databases that are available to the aftermarket retailers.
I recently changed the front crankshaft seal and the oil pan gasket seal on my ’94 SE. I first check on line to get the right part numbers. Then, had the tech at the shop look the numbers up, both numbers matched. Both parts were wrong. The crankshaft seal was too small and the half moon shaped gaskets (one front the other back) were too short. I called 15 retailers in my area and asked for the parts. Each game me the same number, but I had them measure each one (at first, I thought maybe the part box was labeled wrong). Nope, each part at each store was the same and wrong. Then, I had them check the various kits and parts of similar description but with a different name, no one had the right seals. I had to wait and go to the dealer. I ended up paying 30% less for the crankshaft seal and 150% more for the oil pan kit.
I also changed all three belts. The numbers listed in the database for my max were wrong. The long belt was way too long (3 inches) and each short belt were too short. I had the tech match up the original belts to the belts on the shelf to get the right ones. I got all three Goodyear belts for less than the price of the middle size OEM from the dealer.
---JET_MMPro
(BTW, sorry about the incomplete post. That darn 15 post thing. I can’t edit my post and I can’t start a new topic. )
Old May 19, 2006 | 06:49 PM
MrGone's Avatar
I've never had a problem with Gaskets from Napa, but if I was rebuilding an entire engine I'd just use a dealer gasket set. Until recently I didn't have a Nissan dealership close to me, plus wholesale pricing doesn't hurt either .
I did the valve covers/plenum on my friends old 89 SE using parts from and had no trouble at all. It's a toss up I guess. Customer cars and such it's easier to go to the dealer because it removes any and all question (well, should anyway ), but normally I ask if they have a preference. I also only use Napa and dealers. blah blah blah
Old May 19, 2006 | 08:21 PM
Matt93SE's Avatar
STFU n00b!
VG parts are usually not a problem since they're the same as the Z31 gaskets for the most part. the problem is when you try to get engine parts for the VE. they're either mislabeled for a VG30DE, or they simply can't get them for the most part. when I'm ordering gaskets and engine parts (timing chains, seals, etc) I go to the dealer and ONLY the dealer. right part, first time. no waiting. it's worth the few bucks extra.
Old May 20, 2006 | 07:04 PM
internetautomar's Avatar
mod or sell?
You just don't like me
Old May 20, 2006 | 08:42 PM
Matt93SE's Avatar
STFU n00b!
I gots no problem with people that CAN get the parts.... but try going to the local Vatozone and getting a valve cover gasket for a VE.... or a tranny seal.
I've been to the parts store about 15 times trying to get transmission axle seals.. I have nEVER got the correct seal from a parts store, no matter whether it was VG, VE, 5 spd, auto, VLSD, or non.. Head to the dealer and you get the right part every time.
But there are always those few people and shops that can and do get the right parts.
Old May 20, 2006 | 09:38 PM
JET_MMPro's Avatar
The problem I've had with after market retailers really started to happen just in the last two years. I think the problem is in the one or two databases used by the retailers. I only mention it as a caveat. I don't like paying dealer prices.
---JET_MMPro
JET_MMPro's Avatar
---JET_MMPro
Old May 20, 2006 | 09:39 PM
JET_MMPro's Avatar
---JET_MMPro
Old May 21, 2006 | 07:42 AM
mod or sell?
---JET_MMPro
actually the fault lies in the manufacturer when they provide the data not the database.
when people shop strictly by price, something has to give.
Quality is already gone, now they have to cut the people who were checking the data
mvm062
Nov 30, 2020 09:00 AM
dcam0326
Sep 7, 2015 07:26 AM
03VQMAX
Sep 5, 2015 03:47 PM
Johnny9595
Sep 3, 2015 05:18 AM
