Update: Rear Window Regulator
Old Jun 13, 2001 | 10:33 PM
superdesi's Avatar
I finally decided to find out why my rear window quit working.
So it was definately the regulator. It took some time before I was able to take it out but the cable was all screwed up and chewed up.
When I bought the car, the radio, antenna, driver's side door and hood latch did not function correctly.
After fixing all those problems, the window regulator goes out.
I don't mind spending time tinkering with this car, what hurts is when I got to shell out cash.
Old Jun 13, 2001 | 10:57 PM
flyry110's Avatar
3 out of my 4 have been replaced! but the guy that had it before did it! phew! i think he also had the VTC's redone, cause he told me he had like 1500 bucks of "valve work" done. so he probably didn't understand what was going on. anyway, my rear left one is starting to go, it sometimes works fine, othertimes it is a biach! when i pull it forward toward the front of the car it seems to go up easier. the regulator has just got to be going.
Old Jun 14, 2001 | 08:37 PM
Psychosis19
If the cables not too chewed up they can be fixed, just takes some time. My drivers side rear window didnt move when I got my car, took me about 3 hours to respool the cable on the roller, and to rig up a way to hold the top side of the cable in the hole because the plastic was cracked. I used some thin sheetmetal strips crimped around it. so far its been about 2 months and still working like new. Hope this helps save someone else some cash!!!
Old Jun 14, 2001 | 10:09 PM
superdesi's Avatar
Well my cables were chewed up, but still intact. I did try to respool them back on the roller, but then realized that the top holder was broken.
My question is that when you respooled the cable, did you have power to the motor? I would assume that it would be harder to respool it if I brought it to my kitchen table since I would need the motor to turn the roller.
Old Jun 14, 2001 | 11:23 PM
ngthing's Avatar
hey...before your guys windows went...what syndromes did you have?
right now...my windows roll up reallll slow.
Old Jun 14, 2001 | 11:30 PM
superdesi's Avatar
My passenger rear went out. I rarely ever use that one, and I am the only one who drives this car.
One hot day I decided to crack all four windows, about 1 inch for ventilation. Then...all of a sudden...without any warning...I hear a snap*pop*crack. It went without warning.
What I don't understand is that it was rarely ever used. In my opinion, I think that plastic parts just dry and rot out...therefore, they break and then lead to this problem.
Old Jun 15, 2001 | 12:34 AM
flyry110's Avatar
my rear left one goes real slow and then stops, most of the time. sometimes it goes right up. i dont' get it. when i pull the window forard it goes up alot easier and faster, like the window is shifting forward and back. i don't get it.
Old Jun 15, 2001 | 06:14 AM
FFxI30's Avatar
I tired respooling the cable too, but they were to chewed up. You can disconnect the motor which makes the whole process easier. It also helps make sure you dont throw the thing across the room cuz most of the time they are to chewed to fix or the plastic spool broke.
flyry110 - Mine did this after I installed the new regulator, but then I realized that when my g/f was holding the window up, droped it and it fell off track. Dont know if it means your's is no longer in track or what. When they start rolling up real slow its gettin close to you needing a new window motor, at least from my experience.
Old Jun 15, 2001 | 09:25 PM
wizard6161's Avatar
well my windows roll up and down with not problem..but recently they would roll down from the main controller *the one on the drivers panel* but when I try to roll the back up..they won't. I have to do it from each door. like roll the shotgun window from it's own button on it's door and then the backs ones too...from their own doors. WHat could the problem be?
thank you
Old Jun 16, 2001 | 06:54 AM
flyry110's Avatar
mine has done that a few times. just beat on the door ffxmax, thanks for the info!
Old Jun 16, 2001 | 09:36 PM
Psychosis19
No I took the motor off and turned the spool by hand, the motor turned the spool faster than I wanted. As for the top holder I used an old metal strap for the back of a radio and cut some strips out of it, then with a small vicegrips wrapped it around to hold the cable in place.
I'm gonna try and get some pics of this within the next couple of weeks, just gotta find a digital cam...
The Frye
Feb 3, 2019 08:34 AM
cruce91
Sep 20, 2015 10:23 AM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
maximusrising
Sep 4, 2015 06:31 PM
