windshield washer fluid
Hey guys I am not getting any action out of my windshield fluid dispensers. I can hear the motor working when i hit the lever so I am assuming some kind of blockage or the tube has just fallen off. I was just wondering if anyone had ever dealt with this before? Do I just remove that front right panel under the car to get a good look at it? Thanks, CS
Originally posted by C-Dawg
Soak the fluid dispensers in rubbing alcohol or CLR. (Calcium, Lime, Rust remover)It should loosen or dissolve any debris that may have clogged it. I would try this before taking anything apart. You might also want to pour some into the washer fluid resevoir. This might help break it apart from the inside. This is what I did for mine and it worked fine. From now on, you may also want to add a tad bit of rubbing alcohol to the resevoir every time that you refill it. It will prevent it from happening again.
Should I be able to get that at any automotive store? Checked at advance and they didn't have it. CS
Originally posted by Matt93GXE
DO NOT USE CLR NEAR YOUR PAINT.
I think that speaks enough for itself. do it and you'll get ao re-wax the car... that's a best case scenario. worst case is you get to re-PAINT the car.
fastcarny
Oct 12, 2015 07:06 AM
Need help
23
Oct 2, 2015 08:56 AM
