Tranny Leaking...Grrrrr
Old Apr 9, 2006 | 03:16 PM
maxitech's Avatar
Well, my swap is working fine so far except today I noticed that the passenger side axle seal is leaking! It is a new axle seal straight from Nissan. It seems to be leaking around the inner ring between the shaft and seal. There is a metal lip on the shaft that it's kind of leaking around...I'll post a pic later.
Other minor issue is the starter doesn't always switch on the first try...You have to twist the key a couple times...The bolt and/or net that hold the battery connection to the starter is stripped so it's not tightened all the way down.
Anyway, I'd like to get these issues taken care of next weekend. I just want to know why the hell my new seal is leaking!
Old Apr 9, 2006 | 03:39 PM
Hectic's Avatar
did you grease the seals? drop her again
Old Apr 9, 2006 | 03:54 PM
maxitech's Avatar
Yes, and there will be no more tranny dropping for a long @ss time...
Old Apr 9, 2006 | 05:17 PM
internetautomar's Avatar
mod or sell?
maybe it's the wrong seal?
Old Apr 9, 2006 | 07:49 PM
maxitech's Avatar
Pretty sure it's the same seal I removed...Also the leak if relatively small, but having to watch and refill a manual tranny is a PIA. It's alway gotta be somethin'
Old Apr 9, 2006 | 07:51 PM
Alex_V
do you fill through the speed sensor hole? Thats easy. Just have to get 2 funnels or cut oil quart containers.
~Alex
Old Apr 11, 2006 | 03:55 PM
maxitech's Avatar
Here's a pic of the situation...
Old Apr 11, 2006 | 04:33 PM
Hectic's Avatar
looks like your seal's hanging halfway out. from what i remember it should be just about flush with the hole. can you push it in? hope the axle is in all the way, this is the passenger side?
Old Apr 11, 2006 | 05:34 PM
Alex_V
I agree. It may just be the flange but its possibly not in all the way.
~Alex
Old Apr 11, 2006 | 08:42 PM
maxitech's Avatar
The outer part of the ring is flush with the bell housing. It has a rubber lip which is what comes in contact with the metal piece. I got under the car and prodded at it with a tool. More oil would come out when I pushed the rubber lip in.
Old Apr 12, 2006 | 09:44 PM
Alex_V
It looked like more then that lip. I tought that was the cause or the pic was just blurry. it may be a bad seal, or the axle may be scratched on the OD. GL
~Alex
Old Apr 12, 2006 | 11:16 PM
Maxpwer's Avatar
No turbo, no care!
Im guessing you did a swap from an auto to a manual? If so did are you sure you got the right axle?
Old Apr 13, 2006 | 10:38 AM
Alex_V
The axles are the same. he got a VG tranny so any VG axle will work.
~Alex
Old Apr 13, 2006 | 04:30 PM
subs1000w's Avatar
i wouldnt be suprized i remember when we swaped my friends gxe he got the wrong seal also it toook forever to figure out since we thought the seal was fine
MaxStock
Dec 5, 2016 05:19 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
