Crankshaft pulley
Old Apr 13, 2006 | 07:10 PM
Governor's Avatar
Crankshaft pulley
Any good tricks to removing the crankshaft pulley without destroying something? Mine wont budge and I remember a while back someone else on the forum had same problem. I also noticed that the outside edge in one spot looks like it is chipped..will this hurt anything?
Old Apr 13, 2006 | 07:25 PM
SurraTT's Avatar
HR Swap Pioneer
i took the starter off, and jammer a screwdriver in there, this locked it so i could loosen the bolt
Old Apr 13, 2006 | 07:55 PM
Governor's Avatar
I held the pulley with a strap wrench and used impact gun and bolt came right out but now the pulley wont budge. There is not any tapped holes to use a puller so I cant figure out how to get the thing off.
Old Apr 13, 2006 | 08:25 PM
maxitech's Avatar
3-jaw puller. Places like IdiotZone commonly rent them out at no charge. If you have a choice of sizes get the large one.
Old Apr 13, 2006 | 09:15 PM
Governor's Avatar
I have a 3 jaw puller but it wont reach clear behind first two pulleys to the lip. Also I am afraid of busting the lip of the pulley off..I guess I will try to locate a larger one...
Old Apr 13, 2006 | 10:02 PM
aminus21's Avatar
Spray lots of penetrating oil...lot and lots.. i just removed mine to put in a UDP a few months back.. after lots of penetrating oil, I was able to tap it off with a hammer from behind.
urs might be rusted on because of all the salt and stuff they use out there.. if you get a puller, it should come right off..,good luck
Old Apr 13, 2006 | 11:47 PM
nismosleeper's Avatar
I used a oreilly's puller and a 1/2" ratchet w/ a big block of wood. Good luck.
Old Apr 14, 2006 | 07:11 AM
maxitech's Avatar
Honestly, I don't think it will hurt anything, but still try and locate a larger one.
Old Apr 14, 2006 | 10:39 AM
Governor's Avatar
Got it off!!! bought a 6 inch 3 jaw puller and she backed right off...thanks for the help guys..I am now trying to get camshaft seals out..fun fun fun
Old Apr 14, 2006 | 11:03 AM
Jeff92se's Avatar
I'm needing a caw
If you need another stock pulley, I have one. I strongly suggest buying a cheap seal puller. It's worth it, trust me
Old May 23, 2008 | 04:20 PM
KillaKarebear's Avatar
Crankshaft pullet squeak!
so the other i wake get ready for work start the max and what sound wakes me the F* up a loud squeak. after looking i found out it the crankshaft pulley. there only thing is i just know its making noise i dont know if i should just replace it, lube it, or what. if some one can help that would rock my world right now im dying not know if i can drive it or not (which im not by the way)
thanks
Old May 24, 2008 | 12:22 PM
Pearl93VE's Avatar
I can has?
Is it the pulley or the belts? Are the belts tensioned tight enough?? If you don't have splash guards in that area road water/ car wash/ hose can get the belts wet and they will squeak when you first turn the car on.
Old May 24, 2008 | 03:30 PM
BenStoked's Avatar
Jesus was a Zombie.
thanks
the only way i could think a crank pulley would squeak is if the key broke and was just spinning on the crank... if thats the case, and if it isn't too fubar, you just replace the key(proper name eludes my mind atm....) and you should be okay. if its eaten up, may need a new crank.
Old May 24, 2008 | 03:52 PM
you guys are right not crankshaft pulley instead my alt. mount bolts head rusted off or something so now i gotta use a bolt extractor to get the rest of the bolt out and all the other great crap that goes along with. if you guys have any pointer that would be put into use trust me... and i gotta f'n replace the belt tensioner (which had a bend bolt)that was holding up my alt. for who knows who long but after having the max for close 2 months its amazing that i love it but ne way thanks guys i would be lost without the org
Old May 25, 2008 | 01:16 PM
salsaguru's Avatar
nope, not at all...this is little bit more work for me to perform.
02PearlSE
Feb 1, 2016 12:37 AM
rbarnes
Dec 31, 2015 06:29 PM
hayne
Oct 5, 2015 11:53 AM
