oil on plugs
Old Apr 16, 2006 | 12:39 PM
dv3's Avatar
dv3
oil on plugs
i pulled my plugs today and found the TWO cylinders that were misfiring .....both plugs had oil on them.....a good cleaning didnt help it just paid 70$ for plugs lasst summer so i just cleaned them up.....what do u suposse that problem is ? .........help
Old Apr 16, 2006 | 12:43 PM
Greeny's Avatar
¯\(°_o)/¯
Was the oil on the electrode part or the ceramic top part???
Old Apr 16, 2006 | 12:56 PM
dv3's Avatar
dv3
all over the electrode (gap)....from threads down
Old Apr 16, 2006 | 01:01 PM
Greeny's Avatar
¯\(°_o)/¯
Sounds like bad piston rings..
Old Apr 16, 2006 | 01:03 PM
dv3's Avatar
dv3
which means junk it?
Old Apr 16, 2006 | 01:05 PM
Greeny's Avatar
¯\(°_o)/¯
Pretty much,unless you have internal engine rebuilding experience...
You could find a good used engine to swap in....
Old Apr 16, 2006 | 02:18 PM
Hectic's Avatar
don't assume your engine is thrashed just because you have a couple wet spark plugs. first, use a dummy plug, see if you are getting a spark to those cylinders. if you are, then do a compression check. if you aren't, find out why. if the compression check fails, you know for a fact that the engine is toast. at least do a compression check on those cylinders before trashing it.
Old Apr 16, 2006 | 03:22 PM
dv3's Avatar
dv3
sorry but could explain what a "dummy" plug is ...........and how do i do a compression test?
Old Apr 16, 2006 | 05:15 PM
dv3's Avatar
dv3
well it seems to be running better (for now) since cleaning the plugs and a few of the electrical and lubing connections......actually its running much better i actually have some power back....but now it is shifting really hard now that it has power again it is just slams into the gear actaully making my nech jerk ....i didnt do anything to the tranny but check the fluid...anyone know what could be causing this
i just did the tranny self dianostic test ...and the winner is ..."10th flicker is longer: line pressure solenoid valve circuit" according to a post by craig b......any on know what this is?...lol....could it be causing my shifiting problems?
...i also did the ecu test when clean the plugs and connections ...it did not have a "1205 error" for the line pressure solenoid valve ciruit? any ideas why?
Old Apr 17, 2006 | 08:45 AM
dv3's Avatar
dv3
i found it ....there was i plug that didnt get plugged back in right .......wow i got my max back .....runs better than ever(till my my plugs get oily again....amazing what a lil maintance can do...thanks
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
05RLS2
Apr 14, 2016 11:49 AM
trsandrew
Oct 25, 2015 02:47 PM
