Arg!!! Cracked Rear Manifold!
Old Apr 19, 2006 | 04:38 PM
geoff.doctor's Avatar
Well I just had my front studs replaced by a friends dad for $100. Car is a lot quieter, but still made a whistling noise, and wasn't quite as fast as it shoud be. So I got under it, to discover the rear manifold is coming apart, and the studs are all fine!!! Is there ANY WAY POSSIBLE to have this welded up without tearing everything apart and replacing it? I have a good spare from my parts car, but then I need to remove it from two cars, and re-install it on one. I would also have to spend $57 on all new exhaust stud parts again.
Old Apr 19, 2006 | 05:09 PM
goon9's Avatar
Cracked manifolds can be welded... ON a bench with alot of skill if you don't want them to crack again. Sounds like replacing will be your best bet.
Old Apr 19, 2006 | 05:33 PM
RA030726's Avatar
I'm nutty for Nissans
To do it correctly you have to enlarge the crack, heat the whole manifold and then pour on this special powder and heat that up till it melts. You may as well get another manifold.
Old Apr 19, 2006 | 05:56 PM
JstAntrRoky's Avatar
If you pulled it and replaced it you would not have to worry about it again for a long time... The cost does suck, I would have to agree with you on that as that is what I will be doing this weekend... Good luck to you...
Old Apr 19, 2006 | 06:01 PM
maxitech's Avatar
cracked manifolds seem to be a somewhat common problem with you, eh, geoffy!
Old Apr 19, 2006 | 06:06 PM
Jeff92se's Avatar
I'm needing a caw
VE rear manifold? I have an extra for sale.PM me ALOT faster than taking the spare one out. And if the studs were replaced with the upgraded ones, you don't need to replace them again. You should try to get a new gasket though. Nissan 3pc ones tend to fall apart when removed.
Old Apr 19, 2006 | 07:03 PM
vansskaterfreek's Avatar
i also have one too if you dont want jeff's....
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
doctorpullit
Sep 10, 2015 06:33 PM
jds22
Sep 4, 2015 01:52 PM
