Exhaust Manifold
Old Apr 19, 2006 | 04:53 PM
Governor's Avatar
Exhaust Manifold
Ok...I just replaced my timing belt and now I must conquer my leaking rear exhaust manifold. I honestly can not see any broken studs or cracks but it is ticking like a time bomb when I rev the engine. Any tips or advice for tearing this thing off? How can I tell if it is just the gasket or the manifold? I have Matt Blehm's write up on this http://mattblehm.com/faq/REPAIRING%2...LD%20STUDS.txt but any advice you guys could give would be greatly appreciated.
Old Apr 19, 2006 | 05:14 PM
Mizeree_X's Avatar
Getting back to his roots
Here's my experience:
http://forums.maxima.org/showthread....ighlight=studs
Old Apr 19, 2006 | 06:21 PM
JstAntrRoky's Avatar
Mizeree_X that is a job on your exhaust manifold... I feel a lot more comfortable for doing this job this weekend...
Old Apr 19, 2006 | 07:01 PM
vansskaterfreek's Avatar
are you sure your y-pipe felx section isnt broken????? the rear ones are hard to get to.....good luck...
Old Apr 19, 2006 | 07:09 PM
Governor's Avatar
I can feel the exhaust coming out by reaching my hand down on top of rear manifold on drivers side but cant see a damn thing.
Thanks Mizeree_X for the info it is giving me confidance on doing this.
Old Apr 19, 2006 | 07:26 PM
did you take the tin cover off??
Old Apr 19, 2006 | 11:53 PM
mattcomet82's Avatar
edit: nevermind, my pics aren't up anymore. sorry
Old Apr 20, 2006 | 05:11 AM
Brudda Bob's Avatar
I may be wrong here, but I was informed by a mechanic friend of mine that the manifold should be removed and machined in a shop (sanded) so that the new manifold gasket would "seat" properly.
I'm in the process of swapping my engine and recently ordered the studs from http://www.courtesyparts.com/. EACH stud AND nut cost just under $5.00, front and rear manifold gaskets were 14.79 each and I bel. the smaller gaskets that goes onto the y pipe were either a dollar and change or about $3.00 each.Dont recall the EXACT prices.
Old Apr 20, 2006 | 05:43 AM
Mizeree_X's Avatar
I had purchased a used manifold from the org to replace the one on my car, rather than take it to a shop to have it machined.
Old Apr 20, 2006 | 06:14 AM
Brudda Bob's Avatar
Are you saying that it doesnt have to be machined? My understanding is if the gasket is to be replaced then the manifold should be machined. This would pertain to reusing the ORIGINAL manifold or any USED replacements.
It it's unnecessary to have it machined then I guess I'll have some extra beer money!
Old Apr 20, 2006 | 08:06 AM
Jeff92se's Avatar
I'm needing a caw
Use a straight edge on the flange face. I've yet to come across a manifold that was warped to any big degree
Old Apr 20, 2006 | 08:33 AM
That is nice to hear, as I would not even know where to take mine to have it machined.
Old Apr 20, 2006 | 05:47 PM
Governor's Avatar
Not yet but weather permitting I may start taking it apart this weekend.. I went to stealership today to check on studs, nuts and gaskets...62$ hopefully the manifold is not cracked..If so any org members have a rear one in good shape for sale?
Old Apr 20, 2006 | 07:56 PM
when you take the tin cover off, then you should see where it is cracked.... i do have a good rear manifold for the VE laying around in my garage..... if you are interested, Pm me
Old Apr 20, 2006 | 10:22 PM
the tin cover is not meant to be removed. it is spot welded in several areas over the manifold and protects backyard mechanics (like you) from serious burns. driving with busted studs usually leads to warped manifolds, so it is a good idea to have the flange shaved evenly. it's also a good time to take a dremel and grind down your exhaust maniflod ports for smooth flow.
Old Apr 20, 2006 | 10:49 PM
fugi43's Avatar
If you want to get studs that will never snap go with ARP. I purcassed the M8 x 1.25 x 51mm (ARP part # = AF2.000-12GB) studs for $3.29 each. W/shipping my total was $43.74 for 12 studs. The thing is you'll have to call the company directly for this deal since they don't list our application and only sell the "kit" in 10 & 15 packs. Afterwards go down to your local Fastenal/hardware store and purcase stainless steal lock nuts & washers. Some say its overkill, but its worth the peace of mind using stainless steel for a part that notoriously rusts and breaks. here's a link:
http://www.arp-bolts.com/Catalog/Catalog.html
(see catalog pg. 75 for more info) The silver looking ones pictured is what you get. Whats cool is you get the allen wrench starter tip for easy installation.
Thats all I have for now. I broke my left hand and it took me an hour to type this.
lata,
Fugi
Old Apr 21, 2006 | 08:09 AM
oldngivout's Avatar
Willing to learn
I am going to offer my opinion on this issue based on the facts that I have encountered over the years.
I have repaired several Maximas, Pathfinders etc. with the VG or VE engine exhaust leak. I have yet to find one that the manifold was NOT warped and in need of surfacing. You risk breaking another stud when replacing the manifold if you do not ensure that it is perfectly flat. You will be forcing the manifold down flat against the head with the fasteners - not good.
Place a machinist's straightedge flat on the center port, then see if it is necessary to "rock" it back and forth to touch flat on the end ports. My money says yes. How much you can get away with is up for debate; however if properly resurfaced then all doubt is removed.
Yes it is an added cost but this job is not fun to do, much less twice. Parts and labor are high enough; don't shortcut this repair.
Old Apr 21, 2006 | 11:26 AM
Governor's Avatar
I will check this when I remove it..if it is warped I will have it machined..I do not want to do this job again...thanks for all your post's!
Old Apr 21, 2006 | 11:41 AM
alextothestars's Avatar
yes, it would need milled if you drove it for a long time while it wasnt attached properly. you can just buy a new one and it will be alright.
i have headers and i have to tighten the front all of the time.
Old Apr 21, 2006 | 11:54 AM
Has anyone had to have theres machined? And if so how much did it cost you?
Old Apr 21, 2006 | 12:06 PM
Well I guess I should of just picked up the phone book and call as I just did. I called a local Machine shop and can get both of mine milled for about $30.00 for both.
Old Apr 21, 2006 | 12:17 PM
Jeff92se's Avatar
I'm needing a caw
IMHO, the flange doesn't have to be straight down to 0.000001". Because the thick 3pc gasket can accomodate a slight warp.
IMHO it's not the warping of the flange face that breaks the studs. It's the explansion of the bolts holes outward that snaps them. It's always the end studs that broke on mine. Or at least those are the 1st to go. When the manifold is installed the hole has alot of wiggle room but the studs always seem to be on one end of the hole.
Old Apr 21, 2006 | 02:16 PM
Brudda Bob's Avatar
Dont you think the additional $30.00 to have it machined would give you more peace of mind? Just think of the labour, time and additional expense you would have to endure if this situation reoccured because you didnt have it machined.
It's very possible that it doesnt need to be machined and then again it's possible that it does. How do you rest assured and obliterate all doubts? Have it machined!
Do it once, do it right or dont do it at all!
Old Apr 21, 2006 | 03:21 PM
Mizeree_X's Avatar
Looking at the gasket though, I feel like unless there is gross warpage, the gasket has a more inconsistent surface than the manifold itself. Just my $0.02. I did clean up the contact area with some sandpaper and then a polishing wheel.
Old Apr 21, 2006 | 08:10 PM
Governor's Avatar
Raining like crazy here and supposed to all weekend so I will have to put this off for a while..I have not driven it much since I heard the leak..I have a 95 Corolla that I have been driving to work (28mpg) and my Dodge Ram if necessary. I spoke to an old Nissan mechanic today and he said I was over confidant in doing this manifold stud job that it was a real pita even while on a lift not to mention lying on my back in the driveway so I am getting a little woried. ..I say no pain no gain and save myself lots of $$$ and do it myself. I looked this up on All Data and it said 2.2 hours labor?? must mean if it is all new and the motor is out of the engine...Has anyone had this done at a shop?
what did they charge in labor?
Old Apr 21, 2006 | 08:26 PM
oldngivout's Avatar
Willing to learn
Just be prepared for more problems. When I did my last one, I broke two studs off simply REMOVING the old ones. I cannot stress enough the importance of 12 new studs for this job.
Old Apr 22, 2006 | 11:20 AM
Governor's Avatar
I will be replacing all 6 rear ones..hopefully the front ones dont break. Still raining and miserable out.....
Old Apr 23, 2006 | 06:25 PM
Governor's Avatar
The tin cover does not have any bolts..looks like it is part of the manifold..I took a good look at this leak today and I do not see any broken studs..it appears the leak is coming from the top side of the manifold..I will shoot for next weekend...I cant wait to get this back on the road..the Corolla is rattling dog.
Old Apr 23, 2006 | 06:42 PM
well if you need a manifold, i have one.... PM me if you want it
Old May 19, 2006 | 07:46 AM
maxitech's Avatar
ARP has the studs on a 3 week back order, so I'm gonna go with the ones from courtesy...
Can anyone tell me the part number or more details about the studs...They are Z32 (300ZXTT) studs, correct? I talked with a guy in the parts department and they don't list the dimensions.
Old May 19, 2006 | 11:29 AM
Jbr8k's Avatar
Gasket rear #14036-V5000
Gasket frt# 14037-V5000
Stud turbo#14065-V5004
Nut exhaust#14039-W1500
Washer#14037-V5005
Hope this Helps.
Old Jun 11, 2006 | 08:47 PM
maxitech's Avatar
OK, my plans to replace the exhaust manifold studs keep getting pushed back, but it will get done very soon. My "mechanic" friend who volunteered to help me is convinced from talking to some older mechanic that the studs will strip the threads in the head when the broken studs are being removed.
Question being: Has anyone had to remove the head from the engine in order to re-tap the stud hole?
Old Jun 12, 2006 | 06:08 AM
Alex_V
you'd have to replace the head gaskets if you take the heads off. It'd be less work to pull the whole engine.
Im doing something similar. Im swapping in my lower milage VG and fixing the broken studs and putting on a timing belt and water pump and all that fun stuff before I do, makes it easy.
~Alex
Old Jun 12, 2006 | 07:55 PM
Governor's Avatar
~Alex
You can do this with the motor in the car. I just did it but it took me 2 days to complete and I had to drill and tap 2 of the wholes and put heli coils in.You can drop the motor out the bottom at least 6 inches with no problem after removing the cross member and rear motor mount. It is a pretty big job while in the car but it can be done.
http://forums.maxima.org/showthread.php?t=355656
Old Jun 12, 2006 | 08:01 PM
maxitech's Avatar
Sweet...I just needed proof that having to remove the heads is not going to be required...Now he has no excuse for not fixing it. I already payed him with a case of beer!
Old Jun 13, 2006 | 07:02 PM
Governor's Avatar
A CASE OF BEER!!!! dag gone...if you need any tips let me know while it is all still fresh in my head...
Old Jun 15, 2006 | 05:28 AM
maxitech's Avatar
Is it pretty standard to have to helicoil the tapped holes? I'm hoping the new studs will thread right in.
Old Jun 15, 2006 | 04:14 PM
Governor's Avatar
You will only need to drill and tap and add heli coil if you booger up the threads with the easy out..if you center tap the studds and drill straight in you will be ok. I screwed up the threads on two of mine and had to use the heli coils..I must say though that it was easier to drill them out and put in heli coil than it was trying to center tap the broke studs and use the extractors.
Old Jun 15, 2006 | 05:02 PM
Alex_V
I think I read some time last year that you could weld a nut to the stud, that was broken off flush with the head, and the welder wont stick to the aluminum head, just the steel nut and stud.
Also I read of some one using some 10mm toyota studs and they were like $1.60 each or some thing like that. You just had to tap them out.
Man I cant wait to start working on this. But like I said before my engine is out of the car and I have my 240sx to drive in the mean time. I just hope the AC still works, I only used it for 10 minuets in the winter to check it....
~Alex
Old Jun 15, 2006 | 06:35 PM
Governor's Avatar
~Alex
My welding skills are not that fine tuned..when I run a bead with my flux core Lincoln it gets pretty hot and I would be afraid of melting or warping the head
