need help with fogs
Old Jun 15, 2001 | 02:02 PM
maximaracer28's Avatar
i jur oredered new lenses for my stock se fogs..and xeonon bulbs while im at it..but i cant get the damn things off...and i started to trip the nut so i said forget it and now im wonderign what i should do..its too small of an area to fit an impact wrench in..and the 10 years or so of use put a little rust on the bolts and nuts...anyways i can take them off or does anyone know of any tricks on how to get them off? thanks
Old Jun 15, 2001 | 03:28 PM
ghostmax's Avatar
Buy some Liquid Wrench and spray the bolts (let it sit for a while). Rust remover at an automotive store will also do the trick. I just installed my GXE fogs today, and they look great! Good luck with yours.
Old Jun 15, 2001 | 09:08 PM
superdesi's Avatar
Whats the difference between the GXE fogs and the stock fogs that came from the factory with my 91 SE?
Old Jun 15, 2001 | 09:19 PM
JDwyer2821's Avatar
GXE fogs are Bosch and thinner I just put some on my SE. You have to do some custom wiring and buy GXE mounts
Old Jun 15, 2001 | 09:23 PM
superdesi's Avatar
Which are better? How much did those mounts cost? My dealership says the 89-94 Fogs just come in one style and he showed me his database to prove it.
Old Jun 15, 2001 | 11:35 PM
90maximaSE
Exactly.......
It is too small of an area to get a wrench up there to take apart the fog light. So, does anyone knoe how to get up in there to get these damn things off?
Old Jun 16, 2001 | 12:56 AM
JDwyer2821's Avatar
Re: Exactly.......
don't let the dealer tell you that there is only one stlye, four told me that than one dealer finally said yep. mounts $17-20. Try again if they still tell u no such thing as a GXE foglight tell me
Old Jun 16, 2001 | 07:57 AM
Shep's Avatar
I finally just got my fog light housings off yesterday and replaced the lenses after about 2 weeks of trying to figure out how to get them off. There is a few options. To just get the lens off you can try to fit some sort of a screwdriver up behind and take the two small philips head screws out from behind the lens. To get the black housing off as well, try the two screws that are almost straight up in the middle, and the bolt that goes through it. If you can't get those to come off either (which I couldn't), you can try taking the two large philips head screws out from the frame of the car. They might break off, so just drill two new holes and your set. Hope that helps.
Old Jun 16, 2001 | 08:35 AM
where?
the 2 large phillips head your tlkign about..there located where? you said on the frzme of the car..but is this the large bolt or something else? thanks
Old Jun 16, 2001 | 09:13 PM
flyry110's Avatar
i'll tell ya how i got em off, i was doin a reverse 180 in my driveway and i slip off and ripped the front right one off on a mound of snow! ahhhhhhhhh i was bummed, but i thew on a pair of small round yellow ones we had laying around, and they look SWEET!
Old Jun 16, 2001 | 11:04 PM
90maximaSE
No need....
There is no need to be a smart ***......
Old Jun 16, 2001 | 11:30 PM
superdesi's Avatar
Re: No need....
Don't mind 'em. Some always feel the need to respond to a post whether or not their comments are relavent or not, or just plain dumb.
Old Jun 17, 2001 | 12:02 AM
90maximaSE
Re: Re: No need....
Thanks man....I like your rims just to let you know. Where you from?
Old Jun 17, 2001 | 08:40 AM
SEguy182's Avatar
hey maximaracer, let me know how those xenons look in your fogs, i was gonna buy some but the guy said that they look no different than stock, so if u could email me or respond to this post again i would appreciate it.
Old Jun 17, 2001 | 09:33 AM
Shep's Avatar
Re: where?
If you look up where the metal support of the fog attatches to the frame, there should be a bolt with a phillips head on it way up in there. I found that they came off after a little coaxing.
Old Jun 18, 2001 | 09:17 AM
ghostmax's Avatar
On the GXE fogs, if you look under teh bumper, there is a very slim space maybe about .5 to 1 inch. I just slipped a 10 mm (I think) box end wrench and loosened the bolt. I don't know if it's different for SE's. Good luck.
Old Jun 18, 2001 | 09:33 AM
thanks
thanks.i sprayed a can of wd40 on there...so ill try again late ron today..thanks again for your help
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
mpbclutch33
Dec 26, 2015 11:11 AM
trsandrew
Oct 25, 2015 02:47 PM
Calabar
Oct 5, 2015 09:57 PM
