MAF or Knock sensor?
Old Apr 23, 2006 | 12:06 PM
MorrisonMax's Avatar
I have another thread that tried to solve the problems with my car, but even with all the repairs the car still has the same problems:
- Only after car warms up (although, sometimes a little miss when cold)
- Rough idle, down to 400 and fluctuating up to 850.
- Almost stalls at idle
- Rough idle less noticeable in N or P
- Off the line, the car hesitates and jerks until at about 10 m.ph.
- Going uphill, the previous problem would be worse
- If going on a straight away and giving a slight amount of gas, the car
would "burp" and jerk, until more gas was given
- Car squeals when first turned on and in idle, until warmed up
To see all the repairs I have done see the other thread here:
http://forums.maxima.org/showthread.php?t=465638
Do you guys think this could be a MAF or Knock sensor problem? The car works like a champ when its cold, but once it is warm the problems start. The problems are really bad after I have been driving for a while (especially at high speeds), then I turn the car off and come back to driving before it has cooled down. I am pretty much otherwise out of ideas? Thanks for any feedback.
Old Apr 23, 2006 | 01:50 PM
mszilves's Avatar
You may have to reset the curb idle after doing the throttle-body cleaning. Check here:
http://forums.maxima.org/showthread.php?t=467663
Also, you may want to check the TPS.
Old Apr 23, 2006 | 01:56 PM
My car idles at 700 in D. Should I mess with the setting?
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
