Radiator fans not working?
Old Apr 23, 2006 | 02:31 PM
goon9's Avatar
My car hasn't overheated, but I know the radiator fans used to come on. I havn't noticed it at all for a year, not even last summer. Is there a thermastat or sensor to check?
Also.. Where and how do I flush the heater core?
Old Apr 23, 2006 | 03:22 PM
DennisMik's Avatar
i can't beleive that you went through a summer without the fans working. winter time up north, maybe - but not in the south.
the fans are controlled by the ecc based on the water temperature sensor. if your dash gauge works, the sensor is ok. there are 3 relays for the fans by the battery. if you unplug the fan from the wire harness, you can jumper battery voltage to it and test them and see if the motors are good.
12 volts to pin B and ground to pin C runs it at low speed.
12 volts to pins A & B and ground to pins C & D runs it at high speed.
to flush the heater core, disconnect the hoses as they come out of the firewall.
Old Apr 23, 2006 | 03:50 PM
goon9's Avatar
Good to know the sensor is good. Now to check relays. Thanks.
Old Apr 23, 2006 | 03:59 PM
Cliff Clavin's Avatar
Way out West
did you check your ECU for codes? If you have a bad sensor, it will throw a code.
If your car hasn't overheated, maybe you haven't needed the fans.
When you get back from a fairly long drive, let the car idle for a while and see if either the fans kick on or the temp gauge starts rising.
Old Apr 23, 2006 | 04:28 PM
goon9's Avatar
I'll have to try that. It takes about 5 minutes to warm up. I did change the thermostat and since then it'll stay just a tad under the middle mark. I'm losing a little water some where, probubly around the water pump. Not feeling like i sealed that up great.
Old Apr 23, 2006 | 06:52 PM
internetautomar's Avatar
mod or sell?
<snip>
the fans are controlled by the ecc based on the water temperature sensor. if your dash gauge works, the sensor is ok. t<snip>
there are 2 sensors, 1 for the computer and 1 for the gauge.
if you unplug the one for the ECU the fans should instantly kick on.
MattWithTheMaxima
Jun 30, 2017 01:06 PM
vingodine
45
May 21, 2016 12:46 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kirkhilles
Aug 8, 2015 10:53 AM
kenc15
Aug 5, 2015 08:29 AM
