really bad news for the maxima
Old Apr 23, 2006 | 07:29 PM
vansskaterfreek's Avatar
well guys, i just opened toe hood of the maxima..... and in the fluid resivoir for the radiator, i saw ALOT of engine oil..........and i mean ALOT i guess when my tranny went, and i drove it home, overheating almost all the way because my radiator fans dont work, did i blow out a head gasket????? there is a **** load of oil in that resivoir....but the motor runs fine......what do you guys think?
Old Apr 23, 2006 | 07:37 PM
Jaye_96Max's Avatar
yes you blew a head gasket.
Old Apr 23, 2006 | 07:52 PM
belakithom's Avatar
Probably, since you said you overheated all the way home. Good thing you made it home the way the car was.
Old Apr 23, 2006 | 07:59 PM
the funny thing is that the car runs PERFECT with no missing, and i still drove it about 1000 miles after the overheating!!!!!!.... and as of right now, i can start the car, and boom, it starts right up!!!
Old Apr 23, 2006 | 08:28 PM
Jeff92se's Avatar
I'm needing a caw
Because if the leak is inbetween the oil galley and antifreeze galley, it will run fine. If you gots the milkshake oil in the pan, take care of it.
Old Apr 23, 2006 | 08:33 PM
it dont lok like there is water in the oil.....just in the antifreeze resivoir.....well i just tore down the blown VE the other day, so i got to take a look at what to do and stuff....ill probably fix the motor and sell it... anything else needs to be replaced while all the way down there near the bottom of the block?????? the motor has 72k on it........and i DONT want to put alot of money into this motor since i have no money....
Old Apr 23, 2006 | 09:59 PM
maxmaxima91's Avatar
if its an auto...make sure its not auto tranny fluid from the cooler in the lower tank of the radiator... Also, throughtout this did you ever loose any engine oil?
Old Apr 24, 2006 | 06:00 AM
internetautomar's Avatar
mod or sell?
I was thinking the same thing
Old Apr 24, 2006 | 04:02 PM
Maxima Man's Avatar
Of course he lost some engine oil where do you think the oil that was in the radiator came from????
YES.........
If it was me I would be changing the oil in that car every 500 miles if it still was drivable !!
Old Apr 24, 2006 | 05:09 PM
bhunter's Avatar
I think they could make a TV show about you Vans.......The Fast and the Fumbulous.
Old Apr 24, 2006 | 07:25 PM
maxitech's Avatar
that really sucks, dude...how hard is it to change the head gasket on our motor(s), though?
Old Apr 24, 2006 | 07:30 PM
mtcookson's Avatar
unless its just extremely hot out, it shouldn't be overheating due to the fans not working. there must have been something else wrong because these cars are actually pretty good at staying cool. the fans usually only turn on when sitting at idle for a while.
Old Apr 24, 2006 | 07:33 PM
Greeny's Avatar
¯\(°_o)/¯
The head gasket on my parts engine is blown in the same area as yours vans...It runs fine,but will fill the cooling system with oil...probably a weak point in the factory head gasket...Or WAAAYYYY too much right pedal..
And it was a 5 speed,so the trans cooler in the radiator would not be the cause..
Old Apr 24, 2006 | 07:58 PM
i have an auto..........
ill check it out before i tear into the motor..... i didnt even think about that.. tranny fluid.....hmm..... i looked at the dipstick and it looks like there is no water in it.... ill check sometime this week, im pretty busy
Old Apr 24, 2006 | 08:05 PM
Greeny's Avatar
¯\(°_o)/¯
I know you have a auto ...Post #7 and #9 say that the oil in your radiator might be the tranny fluid cooler that runs though the bottom of the radiator...
I was just saying it may actually be a blown head gasket,because my other maxima was doing the same thing as yours is now...
Old Apr 24, 2006 | 08:59 PM
95turbo gxe's Avatar
danm you and maxima's
Old Apr 25, 2006 | 06:57 PM
ohh ok.. i am pretty sure it is oil, i smelled it and it is not tranny fluid.....
Old May 17, 2006 | 08:36 AM
dyme's Avatar
ouch - that doesn't sound good at all.
xUNIxPanther
Aug 27, 2015 10:09 PM
Team STILLEN
Aug 10, 2015 04:29 PM
NERDJUSTBNME
Aug 9, 2015 09:40 AM
