Warpspeed Y-pipe Leaking
Old Apr 24, 2006 | 02:24 PM
avmaldo's Avatar
I bought the y-pipe from warpspeed that doesn't use a flex section. Instead it uses some strange joint with springs. I can't remember what it is called though.
Anyway, my y-pipe leaks at the joint. Anyone have this same problem? Anyone know how to fix the leak?
Old Apr 24, 2006 | 02:47 PM
andy044's Avatar
RWD bolt-on conversion?
i had similar problem. i beleive i could tighten that joint.
it wasnt to rusted. yours may be?
Old Apr 24, 2006 | 03:31 PM
avmaldo's Avatar
I tightened the joint but it didn't do much.
It's not rusted, just looked at it this weekend.
I'm thinking the problem may be with the design of the joint.
Old Apr 24, 2006 | 04:15 PM
aminus21's Avatar
call warspeed and see what they say. they stopped selling these "superflow" y-pipes for some reason a few months ago. GL
Old Apr 24, 2006 | 05:10 PM
internetautomar's Avatar
mod or sell?
things don't rust in AZ they just dry out
Old Apr 24, 2006 | 07:13 PM
MrGone's Avatar
If it doesn't stop leaking I would clean the joint and use some copper RTV
call them and ask though
Old Apr 24, 2006 | 07:59 PM
vansskaterfreek's Avatar
maybe your gasket went bad????
Old Apr 25, 2006 | 06:46 AM
mod or sell?
that joint design doesn't use a gasket and the rtv will come right out as it flexs.
the only solution is a REAL flex piece in there. if that design had actually been usable you don't think an OE would have used it on some car?
Old Apr 25, 2006 | 12:49 PM
avmaldo's Avatar
the only solution is a REAL flex piece in there. if that desing had actually been usable you don't think an OE would have used it on some car?
Thats what I figured... poor design. Had I thought about this before hand, I would have just bought a regular flex section y-pipe. Now that I think about it this thing is probably gonna break some studs soon because its so rigid.
Anyone ever cut and weld a flex section on?
Old Apr 25, 2006 | 01:38 PM
mod or sell?
any muffler shop can do it.
Old Apr 25, 2006 | 01:42 PM
Jeff92se's Avatar
I'm needing a caw
Honda uses it on their 4 cylinder exhaust collector section.
Old Apr 25, 2006 | 01:48 PM
Jeff92se's Avatar
I'm needing a caw
Yes. You had better make sure it's at least this long. Anything shorter will be too stiff and you will keep breaking flex sections. Also if you use this long one, you might have to go to a shorter 4 gen cat or cut out length somewhere else. Also note ball-joint style flanges. Best flanges on the market. No gaskets and sealed excellent everytime.
Old Apr 25, 2006 | 01:49 PM
Greeny's Avatar
¯\(°_o)/¯
Nice welding there ray..
Originally Posted by Jeff92se
Old Apr 25, 2006 | 01:51 PM
Jeff92se's Avatar
I'm needing a caw
Whatever stevie Welding the flex to the extra pipe was easy. Welding the thin **** metal on the Cattman Y was impossible. Cattman Y keep cracking
Old Apr 25, 2006 | 01:57 PM
mod or sell?
as a flex section?
I've seen them used as joints on old chevies, the fwd setup tends to need more flex
Old Apr 25, 2006 | 02:02 PM
Greeny's Avatar
¯\(°_o)/¯
I feel ya there,When i was welding my midpipe hose connectors on i had to leave the slag on them,if i tried to knock the slag off, it just broke whole weld off...
Old Apr 25, 2006 | 02:06 PM
Jeff92se's Avatar
I'm needing a caw
Best pic I could find:
as a flex section?
Old Apr 25, 2006 | 02:11 PM
Jeff92se's Avatar
I'm needing a caw
Those area pain because it's hard to weld in a small circle. I just tack weld it in 2-3 places securely. Then used a 2-part expoxy to make a bead around to seal it. It's the stuff you use to fix punctured metal drums etc... Comes in a stick. You break a piece off and knead it until mixed. The spread it around.
Old Apr 25, 2006 | 02:17 PM
Greeny's Avatar
¯\(°_o)/¯
Yeah i thought about using some of that stuff for the midpipe..Probably would have looked better..
Old Apr 25, 2006 | 04:02 PM
James92SE's Avatar
2 VE's are better than one!
Where did you get the ball flanges?
I've been looking for a while for some but havent had much luck finding anything, and you're right they're good flanges! I'm jealous that my all my brother's Honda stuff uses those gaskets and I'm stuck with the cruddy 2 bolt flanges that leak like crazy no matter what I do
Old Apr 25, 2006 | 04:08 PM
Jeff92se's Avatar
I'm needing a caw
My local header fabricator has them. Not cheap but very worth it in the end. Especially for the number of times I took off the exhaust system.
Old Apr 25, 2006 | 05:55 PM
MrGone's Avatar
Beg the wife for a MIG next birthday/christmas/anniversary (or all of the above combined because they are spendy )
Miller/Lincoln/Hobart with infinite voltage control (or whatever each brand calls it). www.welders-direct.com has free shipping too which is handy because they are heavy
Old Apr 25, 2006 | 05:58 PM
MrGone's Avatar
http://www.stans-headers.com/
Old Apr 25, 2006 | 05:59 PM
Greeny's Avatar
¯\(°_o)/¯
Miller/Lincoln/Hobart with infinite voltage control (or whatever each brand calls it). www.welders- direct.com has free shipping too which is handy because they are heavy
Ok, will email her this post...
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Quickywd01
Sep 21, 2016 09:36 PM
lrb6805
Sep 17, 2015 04:49 PM
