car runs like crap after it warms up - need advice
Old Apr 30, 2006 | 07:31 AM
tripleGmax's Avatar
So my car will run fine before it warms up. Once it warms up it will idle really bad in drive and sorta feel like its bogging down type symptoms. In neutral, it will idle better. When you gas it it sounds horrible like putt putt putt noises.
When driving the only way to get anywhere really is WOT. but then it still doesnt move like it should.
I pulled ECU codes and i got a 55, so that means normal.
How long has it taken you guys to do a tune up on the VG? my buddy and i will be doing it today hopefully.
should i check fuel pump and filter?
any help would be great!
Old Apr 30, 2006 | 07:50 AM
internetautomar's Avatar
mod or sell?
check for a misfire, I wouldn't be surprised if one of the injectors crapped out
Old Apr 30, 2006 | 07:51 AM
GRNMAXDMON's Avatar
i do my maintenance every weekend on both my cars. i check all the fluids and electrical stuff. im just gonna take a guess on a few things on ur problem but don't assume im right. check ur O2 sensor wiring. my '93 would loose massive power but it only seemed to happen when it would rain. i thought it could have been my fuel pump in fact it turned out to be my O2 sensor. when i take a look at it, turns out that the wiring on it was destroyed. the damn sensor wasn't even connected but my check engine light didn't come on at all. so check that out and also check for ur coolant temperature sensor. also change ur fuel filter. i did this yesterday to my '89 and when i blew out the gas out of the filter the gas came out looking black. once i changed the filter the car ran a bit better than before. also check ur MAF and ur injectors also check ur plugs and wires as well as ur distributor and rotor. remember i may not be correct on all this but its worth a try.
Old Apr 30, 2006 | 08:02 AM
tripleGmax's Avatar
thanks grnmax, thats what i plan on doing, the filter, O2 and temp sensor checking.
the past few days have sucked and i wanted to drive this car off a cliff.
it doesnt run great when cold, but better than when it warms up.
thanks for the advice....
Old Apr 30, 2006 | 09:49 AM
MorrisonMax's Avatar
If it does not run very well when cold either, then I would not think o2, as that is a closed loop mechanism. I would guess injector or ignition coil. My car ran much worse when warm than cold, but it was still the coil.
Old Apr 30, 2006 | 10:11 AM
95turbo gxe's Avatar
I would say no on the o2. I drove mine almost 30,000 miles with it disconected, but you may try unpluging it to see just in case. Ok my gues would be bad spark plug wire. or may be some type of vacum leak. Rember things dont leak as bad itill they are warm and soft. My car had a bad wire and would realy run ****ty after it was warm and I put a load on the engine.
Old Apr 30, 2006 | 10:26 AM
Does the 91 SE have spark plug wires? I thought no, but maybe I am wrong.
Old Apr 30, 2006 | 10:48 AM
tripleGmax's Avatar
yeah it does. hopefully the tune up will take care of my problem.
on my list is: ngk plugs and wires, distributor, fuel filter and pcv valve. if that doesnt fix it, ill also get an O2 sensor. if that doesnt get it, then ill blow the car up
thanks everyone for your input.
Old Apr 30, 2006 | 06:25 PM
tripleGmax's Avatar
update
here is an update:
replaced the spark plugs, wires, distributor cap, rotor, fuel filter.
the old plugs didnt have much of a conductor left. I went with the V-power because they didnt have the regular NGK plugs.
car runs great now! thanks for your guys advice. cost $100 and now my car feels like $101 haha. big thanks to SEmy2K2go for helping and giving up his garage
Old Apr 30, 2006 | 07:06 PM
SEmy2K2go's Avatar
Go BUCKS!!!
Glad I could help out to get your car performing well again, Gregg. I would have been so frustrated driving your car around the way it was running.
Old Apr 30, 2006 | 07:15 PM
Alex_V
sheese all that money into mods and no love for a tune up. Stupid ricers.
Glad you got it figured out. I was going to ask you if you did a tune up but figured you had already.
~Alex
Old May 1, 2006 | 06:10 AM
tripleGmax's Avatar
ive been way to busy with everything Alex, I had that tune up planned back in January......
Old May 1, 2006 | 10:02 AM
navyrsrvst's Avatar
I'm having the same type of problems. I'm going to try a complete tune-p and see if that cures
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
