stall, start, CEL... code 55
Old May 2, 2006 | 04:42 PM
Phoenix's Avatar
Lives in a Maxima
Occasionally, now and again my max will stall at idle... or just going down the road... I can restart it immediately, and usually it'll throw a Check Engine Light after I restart it. But every time I check it, I get a code 55. I mean, within 10 seconds of the light flashing, I click the ign into acc (from running), and then back to on so i can run diag, turn the screw, and I get a 55.
Also, when accelerating at heavier throttle, I *may* lose all power. Until I clutch and drop the RPM down to idle, give it a rev to make sure she'll play, and then accelerate out. This will not produce a CEL.
I'm thinking ignition coils.
I replaced the MAF about a month ago, new fuel & air filters last week, 10k on the plugs (copper)... I have been run a few tanks of 87 since Hampton Roads, VA is completely out of anything better...
I guess I just want someone to say it could be something cheaper than coil packs.
Old May 2, 2006 | 04:57 PM
Greeny's Avatar
¯\(°_o)/¯
Sounds like the coils to me dude..
Old May 2, 2006 | 05:02 PM
Phoenix's Avatar
Lives in a Maxima
I just said that's not what I wanted to hear. Damn it. Oh well, it's still what I was expecting to hear.
Old May 2, 2006 | 05:06 PM
Greeny's Avatar
¯\(°_o)/¯
Check the f/s section...I think jeff92se still has rear coils f/s...
Old May 2, 2006 | 07:00 PM
Cliff Clavin's Avatar
Way out West
More than likely the coils, but there are other possibilities. I found when my coil packs were acting up, it did not throw a code.
Have you taken them out and checked for cracks? Cracked ones can cause idle problems.
However, even ones that look perfect can be faulty.
Old May 2, 2006 | 08:31 PM
vansskaterfreek's Avatar
ive got a set of six coils, but they are untested, and i cannot test them since my maxima is no longer registered......only a few have visible cracks i nthe outer housing.....
Old May 3, 2006 | 05:45 AM
Phoenix's Avatar
Lives in a Maxima
Two of my front ones are cracked, all three fronts are wrapped in glass/cloth Class B insulation tape. The rear do not appear to be cracked... and they are not wrapped.
At an average of 30,000 miles a year, I knew the day would come that I could not keep them going any longer.
Old May 3, 2006 | 05:52 AM
Greeny's Avatar
¯\(°_o)/¯
My tape fix didn't last long either...They may also be failing internally....
sctludwig
Sep 1, 2022 01:32 PM
mvm062
Nov 30, 2020 09:00 AM
jwright36
Sep 8, 2015 11:45 AM
trungg86
Sep 4, 2015 04:58 AM
