rough idle in gear
Old May 11, 2006 | 09:07 PM
Nmax92's Avatar
rough idle in gear
I'm getting alot of vibrations at idle(600-650rpms) while i'm in gear. when I step on the gas, the car shudders up to 2k rpms, after that it runs smooth. when the rpms start to return to under 2k the vibrations comes back. that S**t is annoying. does someone have any solutions?
Old May 12, 2006 | 06:08 AM
internetautomar's Avatar
mod or sell?
start checking for a misfire
Old May 12, 2006 | 07:47 AM
Greeny's Avatar
¯\(°_o)/¯
I have heard a bad oxygen sensor will cause this issue sometimes...
I just got a 94 gxe with the same issue,so i am going to unplug it and see if it will stop doing it..
Old May 12, 2006 | 08:38 AM
Nmax92's Avatar
Interneta, how do i check for misfire? do I do the balance test on it?
the problem happens for a day, then the next couple of days to weeks it doesn't do it.
Old May 12, 2006 | 02:53 PM
mod or sell?
sounds like what one of my injectors did to me on my old grey max (#1)
it ended up resolving itself after I lent the car to a friend of mine.
Old May 12, 2006 | 02:59 PM
alextothestars's Avatar
yes, when my car starts shuddering (about twice a year), i run the $12 bottle of chevron/techron injector cleaner through. always does the trick. just did it today and shes running a lot better. could probably use a second treatment like the bottle suggests, but i have to eat with that money!
on another note, when my headers werent fully sealed (had to have the manifold studs replace), i was getting a huge power loss in the engine and violent shaking; i found that it stopped right after i changed my oil (after a few minutes of driving, the car began to run normal) this happened to me twice and only while my exhaust was, technically, disconnected. i can only guess that the oxygen sensor was working incorrectly and that my oil became super dirty?...very weird. thought i had a blown head gasket and it only needed an oil change! (i change my oil every month, mind you). lol. i recommend that you make sure that you can afford any mod you make to your car (at least if youre going to mod it correctly). sensors are no joke.
either way, they are cheaper suggestions to a likely fix.
Old May 12, 2006 | 03:09 PM
redwood_usa's Avatar
heres another cheap try. buy teh crc air intake cleaner . Warm teh car up, put it in idle and then spray the stuff in throught the PCV valve. use about a 1/4 of the can. then take it out for a power ride.
Old May 12, 2006 | 04:06 PM
Greeny's Avatar
¯\(°_o)/¯
Well,i found my problem....SPARK PLUGS!!
It had a misfire under load,so i decided before i tear the whole top of the engine off to change the injectors that i would check the spark plugs..Ugh They looked BAAAAAADDDD!!
20 minutes later it is puurrrin like a kitten...
Old May 12, 2006 | 06:47 PM
Nmax92's Avatar
congrats MyGreenmax, i found my problem. I was hoping it wasn't going to be my injector.....well with my luck it is. the injector does click at all. i'm really limited on cash to get them all changed now. I'm looking around for a good deal on them. what is the correct injector for a gxe?
Old May 12, 2006 | 06:55 PM
Greeny's Avatar
¯\(°_o)/¯
Brian[internetautomart] is the man you need to talk to about injectors....
http://www.internetautomart.com/maxi.../boschinj.html
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
