94 se running like crap
Old May 12, 2006 | 01:56 PM
probmxstyle's Avatar
So it rained its *** off yesterday. Today I get up and take my girl home and everything its fine. I am at her house for about a hour and come back out to leave, I start my car and get a check engine light along with a rough idel. I had a similar feeling last year when I went through a big puddle. And that problem gradually went away, but it also didnt thow a engine light at the time. It is also rough running when I am accelerating and smooths out a little in higher rpm's. Any feedback? Did something get wet?
Old May 12, 2006 | 02:15 PM
Michael's Avatar
Back in a 3rd Gen.
well first thing I would do is check the ECU to find out what the code is since you got a check engine light. Then go from there. Anything else is just guessing and there could be a number of things.
Old May 12, 2006 | 02:28 PM
Ok so I checked the ecu and it put out 5 flashes then 1 flash. So a 51 is injector analysis.
Old May 12, 2006 | 03:42 PM
Anyone know what I should do with this code, or where to start?
Old May 12, 2006 | 04:09 PM
Greeny's Avatar
¯\(°_o)/¯
IT THREW A CODE??????!!!!!!!!!
Wow,it is rare for a 3rd gen to throw a code for anything...
Old May 12, 2006 | 05:01 PM
Hectic's Avatar
considering you were at your girlfriend's house for about an hour, let's hope something got wet
but seriously, sounds like and ignition problem, injector, coils, maybe you're not getting a spark. find out which cylinder is missing first then narrow down the cause.
Old May 12, 2006 | 05:02 PM
KEhrhardt's Avatar
You have a bad fuel injector. Search the org for more info. If it is on cyl 1,3,5 you will have to pull the intake plenum to get at the fuel rail in the back. If it is cyl 2,4,6 you got lucky, and the plenum doesn't have to come off. NubianNupe posted a injector replacement procedure in one of the FAQ's. Check the stickies.
Old May 12, 2006 | 07:50 PM
Cliff Clavin's Avatar
Way out West
Mine showed a code 13 when my coolant temp sensor went out...
Old May 13, 2006 | 08:32 AM
Greeny's Avatar
¯\(°_o)/¯
I have had my ve for 5 yrs. and have yet to see mine set a code for anything...
I guess that is a good thing...
Old May 16, 2006 | 04:22 AM
daMaxse's Avatar
Hmm. I've got the same thing (runs rough after it's been run for a while, is shut down and starts up) going on with my 94 SE. What's wierd here is that sometimes my fuel pump also runs on after the engine is shut down. I end up having to disconnect the negative battery cable.
I will try to decipher the ECU code -- I am getting a check engine light at times. But I am still puzzled over why the fuel pump runs on.
Thank you.
Jim
Old May 16, 2006 | 04:19 PM
internetautomar's Avatar
mod or sell?
you sure it's the fuel pump and not the ABS pump
Old May 17, 2006 | 05:15 AM
daMaxse's Avatar
Good question. It's coming from the pass/side fender area. sounds like a pump that's running. If it is ABS, what does that mean?
Thank you.
Old May 17, 2006 | 05:44 AM
Greeny's Avatar
¯\(°_o)/¯
Thank you.
Passenger side front or rear???
Old May 17, 2006 | 07:22 AM
dyme's Avatar
ECU & codes.
Newb here ! How can I check my ECU for codes when something goes wrong ?
Old May 17, 2006 | 08:24 AM
daMaxse's Avatar
I'm sorry. Front.
Old May 17, 2006 | 08:30 AM
Greeny's Avatar
¯\(°_o)/¯
I'm sorry. Front.
It's the abs pump running....
Old May 17, 2006 | 10:10 AM
daMaxse's Avatar
Okay. Thanks.
Anything to worry about?
Old May 17, 2006 | 10:24 AM
Greeny's Avatar
¯\(°_o)/¯
Okay. Thanks.
Besides running your battery down,i don't think it will hurt anything...
I would just unplug it at the actuator...Your abs light on the dash will stay on after you do though...
You could take the cluster out and pull the bulb to remedy that...
Old May 17, 2006 | 11:34 AM
mod or sell?
to be more accurate, your ABS relay is probably sticking.
Hmmm..... maybe I'll go get a relay for mine that way I MAY get back sum focktional ABS
Old May 17, 2006 | 01:09 PM
daMaxse's Avatar
Thanks all for the help.
captchaos
Mar 15, 2016 12:18 PM
londonflu
40
Sep 25, 2015 09:11 AM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
ballerchris510
Sep 10, 2015 09:35 PM
