how to check the sensors...
Old May 23, 2006 | 05:06 AM
knabini's Avatar
guys, I need your help to locate and check the sensors on my Max. I need to figure out what part(s) is(are) wrong and then purchase any replacements.
I'll appreciate any help. Thanks all.
Old May 23, 2006 | 05:37 AM
Greeny's Avatar
¯\(°_o)/¯
What kind of problem are you having???[symtoms]
Here is a pic for you...
Old May 23, 2006 | 06:33 AM
knabini's Avatar
symptoms - engine stalls, sometimes with an explosion in the tail pipe. I restart it with in 2-3 seconds. looks like the ignition shuts off. I had somewhat similar problem with another car and the fault was in the hi temp sensor.
Old May 23, 2006 | 06:38 AM
Greeny's Avatar
¯\(°_o)/¯
Have you check the ecu for trouble codes???
Old May 23, 2006 | 06:59 AM
knabini's Avatar
yes, I have - the code was for bad knock sensor.
Old May 23, 2006 | 07:09 AM
Greeny's Avatar
¯\(°_o)/¯
A bad k/s will not cause the problems you explained...
It's possible the coolant temp sensor could cause this issue..It's cheap[about$20] so you might want just to replace it..
Other things to look at also:
1.Coil packs
2.Mass air flow sensor
3.Injectors
Old May 23, 2006 | 07:19 AM
knabini's Avatar
injectors - 4 new: 3 in the back, 1 - in front
coil packs - they are expensive, so - they will be the last (reasonably) things to replace. imo, the lack of ignition may not be caused by 1 or 2 bad coil packs; and all of they can't go bad in the same time.
mass air flow sensor - I don't know how to check it. I only measured a resistance between the terminals, but have no idea if those reading mean bad or good sensor.
the coolant sensor - this coulbe the lead - cause it measures the hi temperature (it's contacts coulbe loose or it coulbe just broken).
I will replace it and see how the engine works after that.
Thank you.
Old May 23, 2006 | 07:30 AM
Greeny's Avatar
¯\(°_o)/¯
injectors - 4 new: 3 in the back, 1 - in front.
That still leaves 2 to go bad..Were the replacements new or remans??
coil packs - they are expensive, so - they will be the last (reasonably) things to replace. imo, the lack of ignition may not be caused by 1 or 2 bad coil packs; and all of they can't go bad in the same time..
yeah,i meant 1 or 2 of them..not all at once..You can some good used ones fairly cheap here in the classifieds section..http://forums.maxima.org/forumdisplay.php?f=62
Another thing for the classifieds usually very cheap in there...
the coolant sensor - this could be the lead - cause it measures the hi temperature (it's contacts coulbe loose or it coulbe just broken).
Thank you.
Good luck..
Old May 23, 2006 | 08:39 AM
knabini's Avatar
injectors are new. if those two will go bad, they are exposed and easy to replace.
coil packs -if I buy them used, I don't know if they will fail in 1 day or 1 year. better to get the new ones. besides, I checked all coil packs and they have relatively the same readings. and they all work (when idling.)
Old May 23, 2006 | 08:44 AM
Greeny's Avatar
¯\(°_o)/¯
The coils packs tend to fail under load...but will work fine at idle...
Yes new ones would definantly be better..I was just presenting other options since you metioned the price of them..
maxinout93
Oct 31, 2015 02:04 AM
magiconthetire
Oct 26, 2015 09:03 PM
salty318
Sep 29, 2015 01:21 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
