Need Help with Suspension
Old May 24, 2006 | 06:03 PM
souled's Avatar
Hello all,
I have a slight problem. I recently switched to the 17" 350z rims (stock suspension), and when I have people in the back, the tires rub on the fender well. This is causing my tires to shred up a little bit, and I would like to stop this.
What can I do to 'beef' up the suspension in the rear so that the tires won't rub? It happens when I turn or go over speed bumps (only when someone is in the back).
Old May 25, 2006 | 12:28 AM
505max94se's Avatar
get different tires
Old May 25, 2006 | 05:48 AM
internetautomar's Avatar
mod or sell?
where are they rubbing?
inside edge?
outside edge?
Old May 25, 2006 | 10:53 PM
Sean@Home's Avatar
I dont understand how they can be rubbing unless your also running a huge tire. I've Had 18x8 g35 & 350z rims on my lowered max without rubbing so get new tires.
Old May 26, 2006 | 05:49 AM
maxitech's Avatar
Try using some wheel spacers...it's worth a shot.
Old Jun 1, 2006 | 08:58 PM
souled's Avatar
Sorry, I haven't been here in awhile. Here is a picture of where the tire is rubbing:
Old Jun 17, 2006 | 06:11 PM
super32's Avatar
Donating member? what the?!
did you drop your Max? If so, put stock springs back in to raise it back up.
Or perhaps get some stiffer springs
Or get lower profile tires
OR get some AirBags!!! yeah! (jk on the airbags)
Good luck with your "scraper"
Old Jun 17, 2006 | 06:27 PM
ozzombie13's Avatar
I will eat your children
are your rear struts going to die soon?
Old Jun 17, 2006 | 06:57 PM
BEJAY1's Avatar
Conecarver
Depending how much the rub is, could you roll the fender in & up a bit to allow for enough clearance? I always consider the cheapest solution first.
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
