WATER PUMP TENSIONER? vg30et?
Old Jun 3, 2006 | 10:30 AM
Dysfunctional
can someone show me some pics of the water pump tensioner
or how do you tension the water pump, i cant find it in my haynes.
IS THIS DIFFERENT FOR THE VG30ET? prolly not, jsut wondering.
Old Jun 3, 2006 | 01:39 PM
sublunary's Avatar
i think same tensioner does power steering as water pump. tensioner is between crank pulley and power steering pump
Old Jun 3, 2006 | 02:52 PM
Greeny's Avatar
¯\(°_o)/¯
Did someone say pics??
Old Jun 3, 2006 | 05:31 PM
sublunary's Avatar
you are always on top of it. do you just scan the fsm? i was going to do that but i got side tracked...
Old Jun 3, 2006 | 05:34 PM
Greeny's Avatar
¯\(°_o)/¯
I have a fsm in pdf format..
I just print screen,go to paint and crop out what i want to show..
Old Jun 3, 2006 | 06:17 PM
sublunary's Avatar
how did you get that?
Old Jun 3, 2006 | 09:37 PM
nismosleeper's Avatar
Phat20g.net download the FSM for the 1994 maxima
Old Jun 4, 2006 | 09:01 AM
Dysfunctional
uhh,
i dont have power steering
this si going to mess up the tensioner?
Old Jun 4, 2006 | 04:58 PM
Dysfunctional
is there any other way to tension the belt?
uhh, what should i do
Old Jun 5, 2006 | 07:15 AM
Matt93SE's Avatar
STFU n00b!
put the power steering back on is what you should do.
Old Jun 5, 2006 | 07:35 AM
Greeny's Avatar
¯\(°_o)/¯
Old Jun 5, 2006 | 05:33 PM
Dysfunctional
i threw it out
Old Jun 5, 2006 | 05:45 PM
sublunary's Avatar
now your engine is disfunctional
Old Jun 5, 2006 | 07:50 PM
Dysfunctional
in deed,
i mean i can start my car with it, only like 1000 miles down the road the belt will stretch a little and get a little worn, and it wont fit as tightly as i need, im just wondering how i can run it WITH OUT power steering, and still have my belt tight.
Old Jun 6, 2006 | 06:49 AM
Originally Posted by Dysfunctional
in deed,
Get a bracket fabbed up with a tentioner on it, or find a way to extend your w/p pulley so you can run everything on one belt. I have one belt that runs the alt and w/p.
Old Jun 6, 2006 | 07:33 AM
Alex_V
Isnt that 500-700lb over your front axle heavy?
~Alex
Old Jun 6, 2006 | 10:24 AM
Dysfunctional
wanna send me a pic?
what size belt u got doing that? did u get something fabbed up?
Old Jun 6, 2006 | 10:25 AM
Dysfunctional
~Alex
nah,
i work out
Old Jun 6, 2006 | 11:23 AM
Keep in mind that this is an infiniti qx4 water pump, but this should give you an idea. The belt is from a galant IIRC.
The belt has an extra groove on it, so it hangs over, but it is functional still. Hope this helps...
Old Jun 6, 2006 | 11:32 AM
internetautomar's Avatar
mod or sell?
have fun when that belt shreds completely and flies off because of the wrong # of grooves (been there, done that)
Old Jun 6, 2006 | 12:25 PM
I think that i might be able to switch out the wheel on the alternator with a wider one and prevent that.
Old Jun 6, 2006 | 02:23 PM
Dysfunctional
NICE!!
all i gotta do is put an idler pulley on the altenator bolt like that, i can weld up the altenator to pop out like that,
well ill get started ill let yea know how it goes
... i also have a UR UDP. i dunno if that messes anything else up
Old Jun 6, 2006 | 03:58 PM
mod or sell?
You can, just zap poff the nut with an impact and slap on a new pulley, you can also change pulley diameters then too
Old Jun 6, 2006 | 05:46 PM
mtcookson's Avatar
I'd just get a shorter belt if you are going without the power steering. Just use an old belt that is too long and cut it to size, then take it to the parts store to find one that would work.
Old Jun 6, 2006 | 07:49 PM
Dysfunctional
tried that,
no parts store near me has one
im going out tomorow again and double checking this is total BS!
well if this works im going to get my car running ... maybe tomorow.
Old Jun 6, 2006 | 07:55 PM
Alex_V
then put the stupid pump on and leave out the fluid. Or run one hose to the other and fill the hose mostly up with fluid.
~Alex
Old Jun 6, 2006 | 08:10 PM
DanNY's Avatar
Ad·min·is·tra·tor
~Alex
that pump (even if it's not hooked up) will die very quickly w/o fluid
Old Jun 6, 2006 | 08:21 PM
Alex_V
Yea I know I was just too lazy to finish the post. Im tired....
~Alex
Old Jun 7, 2006 | 03:15 AM
Greeny's Avatar
¯\(°_o)/¯
All this trouble for 5hp...
Old Jun 7, 2006 | 03:59 AM
mod or sell?
You're grossly over estimating
Old Jun 7, 2006 | 03:08 PM
Dysfunctional
no i dont want it in the engine bay, and i didnt feel like hooking up after i did the engine swap
Miket2006
Mar 1, 2021 03:55 AM
uttadms31
Sep 30, 2015 05:24 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
