stupid brake question
Old Jun 4, 2006 | 01:29 PM
ozzombie13's Avatar
I will eat your children
what way do the slots on sloted and cross drilled rotors face
like this /
or like this \ this is on the driver side
Old Jun 4, 2006 | 03:32 PM
Greeny's Avatar
¯\(°_o)/¯
Google is your friend...
http://www.stoptech.com/tech_info/faqs.shtml#16
Old Jun 4, 2006 | 06:00 PM
ozzombie13's Avatar
stop tech says that the internal veins should face towards the back of the car at the top of the rotor. the brembo ones have non directional veins. they all face straight out from the hub.
Old Jun 4, 2006 | 06:08 PM
Greeny's Avatar
¯\(°_o)/¯
So your question is???????????
Old Jun 4, 2006 | 06:23 PM
ozzombie13's Avatar
mine shouldnt matter that the slots face up towards the back of the car at the top of the rotors and not foward like other cars i have seen
Old Jun 6, 2006 | 05:49 AM
mwwood77's Avatar
The grooves are cut to allow brake dust to escape the rotor. As the dust builds up between the pads and rotors, it creates more heat and a higher chance to warp the rotors. By having the slots on the front rotors face the front of the car you are actually forcing the dust into the rotor not away from it. You'll want the slots on the front rotors facing the rear of the car.
Old Jun 6, 2006 | 06:33 AM
Greeny's Avatar
¯\(°_o)/¯
Wrong.....The slots are there to allow hot gases,not dust to escape though the slots,thus cooling the pad and rotor to allow better braking...Heat is what causes brakes to "fade"....
Old Jun 6, 2006 | 05:29 PM
ozzombie13's Avatar
ok but my brakes are on the car correctly. and they work good now i just need to figure out the rear drums or to convert to disc
Old Jun 7, 2006 | 10:45 PM
Sevorg1's Avatar
ding ding ding excess dust causes heat? ..........riiiiight
Old Jun 13, 2006 | 11:07 AM
mwwood77's Avatar
I can say neither MyGreenMax94 or myself is correct by ourselves. It is the combination of dust and gases that create the fade and heat. I'm not here for a pissing match, just here to help with I can and gather information myself.
Old Jun 13, 2006 | 11:55 AM
jkmay01's Avatar
Lil 8
very true the gas and the dust that is produced from heavy braking causes less stoppage, so the grooves in the rotor should face back to move the gas away and off of the rotor face so the pad and stay seated on the surface=better braking. the slots also cut the pads to keep a clean surface on the pads
Old Jun 13, 2006 | 11:57 AM
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by jkmay01
very true the gas that is produced from heavy braking causes less stoppage, so the grooves in the rotor should face back to move the gas away and off of the rotor face so the pad and stay seated on the surface=better braking. the slots also cut the pads to keep a clean surface on the pads
I thought they just cleaned the dust off the rotor...
Old Jun 13, 2006 | 11:59 AM
jkmay01's Avatar
Lil 8
lol could be lol
Old Jun 24, 2006 | 12:35 AM
jguo2002's Avatar
my brake always sound noise when driving. How can i fix it? Thanks for replay
Old Jun 24, 2006 | 05:14 AM
jlars205's Avatar
What kind of brakes? If they're slotted/cross-drilled they will make more noise than the stock disc brakes. It happens on my dad's car and I've been told its not uncommon for upgraded brakes to make more noise in exchange for more stopping power. I don't think there's a way to fix it.
Old Jun 24, 2006 | 11:47 AM
jguo2002's Avatar
My car has the disc brakes. Do you know what's problem with the noise? Thanks!
Old Jun 24, 2006 | 01:43 PM
jlars205's Avatar
Probably the same as with mine. Some people have told me the problem was with glazed (permanently overheated) pads or a warped rotor rubbing together. Basically, there's no way to know unless you take the car in and get it checked out. Tell them not to work on anything unless they call you first. I wouldn't reccommend going to nissan, though. Charged me an arm and a leg just to tell me they can't find any noise. Give them a couple things to look for at the very least.
Mar 12, 2020 12:06 AM
BkGreen97
Apr 2, 2016 05:47 AM
Johnny9595
Sep 16, 2015 07:20 PM
bbsitum
Sep 11, 2015 04:55 PM
Johnny9595
Sep 3, 2015 05:18 AM
