ve timing check
Old Jun 5, 2006 | 06:40 PM
sublunary's Avatar
ve timing check
one of the methods the fsm says (the one without the sst whatever that is...) is to use a "suitable high tension wire" to bridge the #1 coil to the plug. you would then hook the timing light to that wire. what do you guys do/use?
Old Jun 6, 2006 | 07:13 AM
internetautomar's Avatar
mod or sell?
spare spark plug wire
Old Jun 6, 2006 | 02:41 PM
sublunary's Avatar
what do you do, cut off the two ends and tape one to the coil. how do you make the connection to the plug? i guess a wire from a vg would be perfect huh... ok i was a little slow there
Old Jun 6, 2006 | 02:54 PM
Jeff92se's Avatar
I'm needing a caw
I am able to get a signal from using a normal inductive type timing gun. The gun is just BARELY big enough to fit over the #1 coil wire close to the connector. If you have a FSTB, you usually have to undo the bar (one allen/nut) and swing it up. Then you may have to undo one of the support brackets to gain access to the wires. Sometimes you have to jiggle and fiddle with it but I get it work everytime. If you have ABS, I feel for you trying to read the crank. When you get a chance, I would put some Liquid paper on the crank notches so it's easier to see
Old Jun 6, 2006 | 05:28 PM
todamax's Avatar
I used a spark plug wire that I had sitting around from my VG days. Worked perfectly.
Old Jun 6, 2006 | 06:59 PM
sublunary's Avatar
thanks guys i am going to install a udp this weekend and i have never checked the timing so it seems like is high time to do so
tsi6001
Oct 3, 2022 10:23 PM
CorollaULEV
30
Aug 9, 2021 08:11 PM
acw
Aug 13, 2015 12:50 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
