Short in tail light
Old Jun 6, 2006 | 06:21 PM
Juicey's Avatar
This ORG has saved me $$$$$$$$
Short in tail light
The outside passanger tail light, which I guess is the brake light (the light that comes on when you hit the brakes) keeps blowing out so I know it's a short. Also sometimes the stereo will change volume when the brake is applied which I take as just part of the problem.
Anyone have any experiance with shorts? Is it as simple as finding whatever wire is exposed and grounding out/creating resistance?
I'm guessing I should just open the brake light and look around. Again, any advice before I take it to the shop/give up would be much appreciated.
Thanks again guys!
Old Jun 6, 2006 | 06:44 PM
Greeny's Avatar
¯\(°_o)/¯
Check the brake light sockets for corrosion...
Old Jun 6, 2006 | 06:49 PM
Josh's Avatar
6-6-6 <-- there is your answer.
But seriously, are the bulbs in there the correct ones? That will cause them to blow quickly. As for the radio, is it stock or aftermarket? Thats an interesting problem my alpine does something like that but I believe that the **** is screwed up.
Old Jun 7, 2006 | 12:36 AM
maxrailfan1's Avatar
I had a problem with my brake lights. I didn't know I had my left side out until a police officer pulled me over and gave me an repair order. I found out the wire leading to the brake light contacts inside the socket was actually burnt on both sockets . The wire leading to the taillight contact inside the socket was good. The brake light contact of the 1157 bulb actually melted to the socket and caused a short. Hope this helps.
Old Jun 7, 2006 | 04:57 AM
Juicey's Avatar
Thanks for the info!
matts95max
Apr 23, 2025 10:44 AM
fastcarny
Oct 6, 2015 10:42 AM
Maxie40
Sep 14, 2015 11:28 AM
jwright36
Sep 8, 2015 11:45 AM
Maxima30
Sep 7, 2015 06:13 PM
