Spark plug socket problem
Old Jun 20, 2001 | 12:58 AM
superdesi's Avatar
To remove/install the spark plugs an extension is a must.
I have no problems removing them. But sometimes when I install them, and then try to pull the socket off the plug, the socket stays attached to the plug and the extension bar comes out.
I have a Craftsman quick-release 3/8" rachet and it locks in the extension. But I have no way of locking in the socket to the extension.
What do you guys do to solve this?
Old Jun 20, 2001 | 01:37 AM
dutch007
One little trick I sometimes use is to get a normal deep socket, put the spark plug in the socket and put a little piece of tape on the socket and plug to prevent the plug from falling out when you go to thread them in.
Old Jun 20, 2001 | 05:14 AM
MGessner's Avatar
Duct tape the socket to the extension?
Old Jun 20, 2001 | 08:28 AM
superdesi's Avatar
I have tried that
I have tried that! Instead of duct tape, I used electrical because it can stretch. I tightly wound it around it carefully. The problem is that it sometimes gets "chafed" while inside the hole and I don't want bits of it to fall down the combustion chamber.
But that was a good thought.
Old Jun 20, 2001 | 06:36 PM
andy90se5spd's Avatar
before installing the spark plug, try spraying some silicone spray in the area where the rubber holds the spark plug. it works a couple times, then you have to spray again.
if all else fails, use needle nose pliers to pull the socket out. it will take a little dexterity to get it in there.
mvm062
Nov 30, 2020 09:00 AM
9aj9
Apr 5, 2020 12:11 AM
cruce91
Sep 20, 2015 10:23 AM
chernandez1278
Sep 16, 2015 01:18 PM
JoshG
Sep 5, 2015 10:10 PM
