bose speakers
Old Jun 26, 2006 | 10:40 AM
MyBlue92Maxima's Avatar
bose speakers
just wondering, does anyone know the wattage that the stock bose systems put out?
Old Jun 26, 2006 | 12:17 PM
Cliff Clavin's Avatar
Way out West
they are crap, I wouldn't worry about it. Probably less than 20w per channel. They also run at 1 ohm, so they aren't very compatible with a standard aftermarket system.
Old Jun 26, 2006 | 12:28 PM
mrkanda's Avatar
Taking my Maxima to the Max!
I was thinking to upgrade my Bose system with a replacement head unit from a 4th gen Max with the CD/Cassette combo. I installed it, and it worked for a couple minutes but was scratchy, then it just cut off. I think my speaker amps are just blown. Should I get them repaired/replaced? Can they be made to sound better with reapaired amps or better amps? I would kind of like to keep the stock look but have decent performance. What do you think?
Also, I was thinking to add a CD changer that can handle MP3s to the stock Bose Unit. Do you think that's doable?
Old Jun 26, 2006 | 12:29 PM
mrkanda's Avatar
One more thought, what about swapping the 3rd gen speakers with Bose speakers from later gen Nissans? Would they work any better?
Old Jun 26, 2006 | 03:45 PM
internetautomar's Avatar
mod or sell?
1. if you want to keep the bose, just repair your amps if you can solder.
2. there is a mod out there for the 4th gen bose H/U to have an aux input for XM, iPod etc...
Old Jun 27, 2006 | 06:58 AM
cparker5's Avatar
Do these speakers cause a problem with changing the stereo system?
Old Jun 27, 2006 | 07:07 AM
mod or sell?
yes they do.
some stereos will work fine with them directly, some won't.
Old Jun 27, 2006 | 07:10 AM
cparker5's Avatar
I want a Sirius and iPod Ready stereo. Any chance ther eare reviews or something of which ones work good?
Greeny's Avatar
¯\(°_o)/¯
I have had good luck with pioneer HU's being compatible with the bose speakers...
Old Jun 27, 2006 | 07:13 AM
cparker5's Avatar
Sorry newbie here. HU stands for Head Unit?
Do you need special conections or something?
Old Jun 27, 2006 | 07:47 AM
Greeny's Avatar
¯\(°_o)/¯
Yup, HU= head unit...
You need a aftermarket wiring harness made by Scosche...Walmart carries them..
And you will also need a antenna adapter...
Old Jun 27, 2006 | 08:48 AM
cparker5's Avatar
Thanks. Some dude a Best BUy was telling me because of the 8Oms from the Bose speakers I would need to get some $150 rig to reduce it to 4Oms because of the wiring or something. It sounded like BS, but wasn't sure.
How hard is it to do a stereo installation with Sirius Tuner myself?
Old Jun 27, 2006 | 09:30 AM
cparker5's Avatar
Would this be a good Setup compatible with the standard BOSE system in the 1992 Maxima SE?
Pioneer DEH-P6800
SIR-PNR2
CD-IB100II
Old Jun 27, 2006 | 10:34 AM
Greeny's Avatar
¯\(°_o)/¯
If you are going to spend that kind of $$ on stereo stuff,might as well get some GOOD speakers too...
Old Jun 27, 2006 | 12:05 PM
Tom91GXE's Avatar
Do yourself a favor, rip anything out that says bose on it and put in something nice.
Old Jun 27, 2006 | 12:18 PM
JET_MMPro's Avatar
Seriously, do yourself a big favor and replace the Bose speakers. The complete OEM Bose system sounded fine originally, but now you're upgrading---don't forget the speakers.
---JET_MMPro
Old Jun 27, 2006 | 12:24 PM
cparker5's Avatar
I am only upgrading so I can have integrated Sirius, I am not really all that sesative to slight sound changes.
But if I did replace the speakers about how much would that addition cost me? I don't need top of the line.
I am more intersted however to make sure I get a good intergrated Sirius system. Hopinf I do not have to do that $150 rewiring.
The car currently has a Sony CDX-C480 in it, is that the factory model, or does that mean the last owner got their own Head Unit?
Old Jun 27, 2006 | 12:38 PM
Greeny's Avatar
¯\(°_o)/¯
Any standard 6x9 aftermarket speaker will fit in the rear pods...It's the front that needs to be modified for aftermarket speakers...
Here is a thread with a ebay link for a aftermarket speaker bracket..
http://forums.maxima.org/showthread....highlight=bose
Old Jun 27, 2006 | 01:02 PM
cparker5's Avatar
Cool, if I go the speaker route that will help!
I mentioned aboive currently the Sony CDX-C480 is installed in the car. If I buy a Sony CDX-GT400 (which is Sirius Ready) should I be able to install the Head Unit with the connectors already used in the current setup?
I guess what I am asking is, since I am stiking with Sony will they have the same wiring/install kit for the same car type and year?
Old Jun 27, 2006 | 03:54 PM
mod or sell?
all you need is an adapter harness and antenna adapter.
you can get them for about $10 ea.
you don't NEED to rewire them, you can reuse the stock wires. I did and it sounds OK, but then again I've got a crappy HU.
The Bose in my I30 sound ALOT better than my aftermarket setup in my max
Old Jun 27, 2006 | 03:56 PM
DigitalMaxima90's Avatar
my bose system was blowed/not working when i got it. changing out some fuses to see it it works. only rear right speaker works at the moment. hopefully the fuses make it work. b/c my mom has a 99 Maxima SE n her Bose system sounds nice.
Old Jun 27, 2006 | 04:21 PM
PovCityHustla's Avatar
Ive seen a 3rd gen maxima ad that brags about the bose system being 200 watts of power?..
Old Jun 27, 2006 | 04:35 PM
Greeny's Avatar
¯\(°_o)/¯
Old Jun 27, 2006 | 06:08 PM
cparker5's Avatar
I can't stand Best Buy, they won't let me install this without rewiring it. Time to buy online and try it myself.
Old Jun 27, 2006 | 06:57 PM
mod or sell?
do it yourself
I did.
to make my life easy, I just cut the harness off my bose harnesses to allow me to wire every thing up outside the car so it was just plug and play once it was bolted in.
don't forget that you need some sort of adapter plate for the front.
Personally I made my own
Old Jun 27, 2006 | 07:02 PM
cparker5's Avatar
Actually talked to Sony Live Support tonight and they said if I curretly have a CDXC series installed the CDXGT series should be just plug and play. No need for anything extra.
Now installing the Sirius tuner is the X factor.
Old Jun 29, 2006 | 08:28 AM
so your saying realli the BOSE speakers r ****ty. but in my moms 99 SE they are really good. I havent really driven my car much since i got my max last saturday n cant drive til this saturday once i get an alignment. n only my right rear speaker works. soo i have to upgrade anyways. my uncle said for me to get 4 6x9's put in back. n some other speakers in the front doors. would i have to cut two more hole for the two extra 6x9s. because i want big sound w/o subs. n i will b running like 300watt amp to the fronts n like 600watt amp to the 6x9s.
Old Jun 29, 2006 | 08:41 AM
mod or sell?
the 4th gen bose speakers are different then the 3rd gen.
the 4th gen runs what looks like a 6.5 in the rear
don't know if all 4th gen bose has it, but I've also got tweeters in the A-pillars on mine
Old Jun 29, 2006 | 08:48 AM
AscendantMax's Avatar
Why would anyone put that many speakers on the rear deck is beyond me. If you're craving for "big sound" without the use of subs, deaden your front doors, and install a quality 6.5" component set. The rears you can just get any replacement speaker and use for rear fill. The front speakers are much more important, since they're the main units that reproduce the sound you hear. In the end, you'll save money from any unnecessary fabrication (ie cutting your rear deck to pieces) and still retain proper front stage imaging.
Old Jun 29, 2006 | 09:33 AM
cparker5's Avatar
So the 3rds ar enot very good?
Old Jun 29, 2006 | 12:07 PM
JET_MMPro's Avatar
"If you're craving for "big sound" without the use of subs, deaden your front doors, and install a quality 6.5" component set. The rears you can just get any replacement speaker and use for rear fill. The front speakers are much more important, since they're the main units that reproduce the sound you hear. In the end, you'll save money from any unnecessary fabrication (ie cutting your rear deck to pieces) and still retain proper front stage imaging."
Absolutely the way to go.
One alt step would be to use a pair of 6x9's with quality low frequency capabilities in the back and cross them at the amp so these 6x9's only play the bass and subbass. You'll have to seal them to the deck really well. 600w going to quality 6x9's playing only low frequencies should give you big sound.
As is clear from other threads in this forum, there is plenty of air space and clearance behind the OEM grills up front, so your speaker choices will include many high quality options.
Let us know how this project goes.
---JET_MMPRo
Old Jun 29, 2006 | 04:30 PM
mod or sell?
they are good for what they are, but better options are out there.
Old Jun 30, 2006 | 06:24 AM
ok. maybe he meant put 6x9s all around. i dont really understand what he was telling me it was hot n we was puttin in a fuel pump on his car on the side of the road. after it broke down the night b4. turns out he only needed gas. but, the fuel pump was in dier need of replacement.
magiconthetire
Oct 26, 2015 09:03 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
