i got owned by a caliper....(see inside for details)
Old Jun 29, 2006 | 06:15 AM
tripleGmax's Avatar
So I replaced my front brakes and rotors about 2-3 weeks ago. Everything was good up front. I knew that my rear pass. side caliper was getting bad. it was kinda frozen....well now its totally frozen. the whole time driving I get a sqweeeling sound. horrible sound. so several months ago when Alex_V was parting out his car i took his caliper from his 1990 se. So last night as i was putting that caliper on my car i got owned!
The 1990 caliper is smaller than my 91s caliper. The pads are a huge difference in size. And the the smaller caliper wouldnt even bolt to my hub assembly.
I had no idea this would happen so my car is sitting in a barn on jack stands as it was around 10pm when we got to this predicament. SO tonight ill have to put the new pads, rotors and new caliper on the rear pass and finish the drivers side rear real quick and bleed the brakes.
so if anyone wanted to know the rear 1990 calipers are not the same as the rear 1991 calipers. does anyone know if the fronts are smaller as well or not?
Old Jun 29, 2006 | 06:20 AM
Greeny's Avatar
¯\(°_o)/¯
Front brakes caliper/rotors/pads are all the same from 89-99..
Not sure what year/type they change around on the rear.Maybe matt/brian can help there...
Old Jun 29, 2006 | 07:41 AM
Mizeree_X's Avatar
Getting back to his roots
Rear brake design changed after 9/90 or something like that, so yeah they are different.
Old Jul 1, 2006 | 07:35 PM
eric93SE's Avatar
dude has a barn
Old Jul 2, 2006 | 02:36 PM
fastflyingasian's Avatar
yes my car was made 10/90 and it has the larger brakes. i found that out the hard way.
Old Jul 2, 2006 | 02:44 PM
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by eric93SE
dude has a barn
Dats how it's done in da sticks mang.
Old Jul 2, 2006 | 03:15 PM
kcidmil's Avatar
Hmmm... I wonder if the brackets could be swapped over.
dude has a barn
Could have been worse, he could have mentioned that he needed a fix asap as the cows we're pissed off he had the Max in there...
Old Jul 2, 2006 | 03:23 PM
Greeny's Avatar
¯\(°_o)/¯
Thats what i was thinking..
Old Jul 2, 2006 | 06:12 PM
goon9's Avatar
Here what I have now and works.
91-94 Calipers.
91-94 brackets.
89-90 Rotors.
Old Jul 2, 2006 | 06:38 PM
internetautomar's Avatar
mod or sell?
I thought your pic showed the rotor being too small?
or did you swap the strut bracket too?
Old Jul 3, 2006 | 06:43 AM
tripleGmax's Avatar
i didnt think the 89-90 brackets even bolted to teh hub assembly.
Old Jul 3, 2006 | 08:15 AM
Alex_V
I could have gotten you those if you needed them >< they are on my pos parts car.
Oh well gald you got some new parts.
~Alex
Old Jul 3, 2006 | 08:18 AM
tripleGmax's Avatar
yeah its great now. stops way better no screaching sound from a frozen caliper and warped rotor. money i didnt want to put into the damn car though.
Old Jul 3, 2006 | 08:27 AM
goon9's Avatar
That was with the older brackets.
Old Jul 3, 2006 | 12:50 PM
mod or sell?
the caliper bracket or strut bracket?
Old Jul 3, 2006 | 01:48 PM
goon9's Avatar
Strut bracket
Old Jul 3, 2006 | 05:28 PM
mod or sell?
so you used the new caliper (and it's bracket)
bolted to the old strut brackets
with the newer rotors?
is that all correct?
Old Jul 4, 2006 | 01:11 PM
goon9's Avatar
Let me try again
Newer Caliper with bracket, newer strut bracket, and older rotor.
Old Jul 4, 2006 | 07:49 PM
mod or sell?
ok, so basically you used evrything from the newer style but the rotor, I wonder if the newer style would have worked too.
Old Jul 5, 2006 | 05:08 AM
goon9's Avatar
The newer rotor was too big. I believe it had something to do with the strut/ hub section being a little different.
I donno whats it's called, but the part that the strut caliper bracket bolts to.
Old Jul 5, 2006 | 06:24 AM
mod or sell?
hmm the rotor diameters are the same, but the height is marginally different.
oh well, live and learn
Old Jul 5, 2006 | 12:06 PM
goon9's Avatar
Thats what i thought. Possibly they gave me the wrong ones???
Old Jul 5, 2006 | 05:29 PM
mod or sell?
very possible
they weren't bought from me so
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
AaronL
Aug 8, 2020 10:31 AM
doctorpullit
Mar 29, 2016 11:08 AM
fx4five
Oct 1, 2015 04:58 AM
