Can I Jump Wire an Injector?
Old Jun 30, 2006 | 11:49 AM
tobinaz's Avatar
GXE SOHC 94 replaced fuel injector still intermitent problem where if disconect spark plug wire engine makes no diference on piston # 2 only.
Help me please!
Old Jun 30, 2006 | 02:01 PM
internetautomar's Avatar
mod or sell?
did you test the old injector before you replaced it?
did you check for injector pulse?
Old Jun 30, 2006 | 04:47 PM
Hectic's Avatar
what do you mean by "jump wire"? are you saying that you want make a bridge from another injector?? if so, the answer is no. have you checked for a spark? even if you have, try replacing the spark plug and that wire, may be shorting out. might also be corrosion on the #2 harness.
Old Jul 1, 2006 | 06:17 AM
nismosleeper's Avatar
Help me please!
Are you getting spark on that cylinder? You can't jump wire the injector. If you run a hotwire, then it won't pulse, and if you connect it to another injector it won't pulse at the right times. Make sure to clean your connector and make sure that it is getting spark(take the wire off and arc it to see spark).
Old Jul 3, 2006 | 08:42 AM
tobinaz's Avatar
Thanks Guys, It Ended Being A Broken Spark Plug. Car Is Runing Better Than Ever
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Need help
23
Oct 2, 2015 08:56 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
