Hi i need help
Old Jul 4, 2006 | 07:14 AM
  #41
Greeny's Avatar
¯\(°_o)/¯
He's trying to catch up to me
No hope there..
Old Jul 4, 2006 | 08:06 AM
  #42
internetautomar's Avatar
mod or sell?
Originally Posted by MyGreenMax94
No hope there..
you started out to slow mang.
you gonna come up here for maxus next year?
Old Jul 4, 2006 | 08:08 AM
  #43
Greeny's Avatar
¯\(°_o)/¯
Yeah,most likely...I'll probably just stay with my relatives and save a few hundred $$ on hotel fees..
Old Jul 4, 2006 | 08:11 AM
  #44
mod or sell?
good then I can recruit you to help run it
or at least make you work saturday when i can't
Old Jul 4, 2006 | 08:13 AM
  #45
Greeny's Avatar
¯\(°_o)/¯
As long as it's easy work..
Old Jul 4, 2006 | 08:15 AM
  #46
mod or sell?
Should be.
hopefully it will all go off without a hitch
Old Jul 11, 2006 | 08:26 PM
  #47
Poppz-93Max's Avatar
In desperate need of troubleshooting advice!
Greetings folks,
I'm new here and shouting from Los Angeles, Ca
I have a 3rd gen 93 Max SE (VE30DE eng)
Experiencing extremely rough starts… engine turns over 30 to 50 times, then finally starts (but only with the throttle in the wide-open position)
Once started the engine sounds fine strong and healthy, but when I let off of the throttle it abruptly shuts down.
So far, I've done the troubleshooting and repairs myself and here's what I have replaced as of yesterday:
Fuel filter, spark plugs, thermostat and water pump… I've checked the ECU codes which only repeats 05 05, and also tried adjusting the crank sensor unit accordingly but to no avail. I've also checked the fuel pressure and its good. The starting problem still persists
Please advise as to what-where I should be checking or replacing.
Many-thanks,
Poppz-93Max
Old Jul 12, 2006 | 12:18 PM
  #48
92 Max's Avatar
Originally Posted by Poppz-93Max
Greetings folks,
Many-thanks,
Poppz-93Max
Pull the plugs, after parking a while, and check for raw gas. Could be a leaking seal or injector.
Old Jul 12, 2006 | 12:22 PM
  #49
92 Max's Avatar
Hood Paint
The hood paint is the first to go because you're in TEXAS!!! Seriously, sun beats the heck out of paint, and engine heat attacks it from the other side. Is the inside of the hood still insulated with mouse fur liners? If not this could make the engine heat transfer worse.
Old Jul 12, 2006 | 08:10 PM
  #50
vansskaterfreek's Avatar
is it possible to drift in reverse in our maximas????
:attention heh
Old Jul 13, 2006 | 07:28 AM
  #51
mod or sell?
:attention heh
:bigbanstick:
Old Jul 15, 2006 | 07:12 PM
  #52
colinod's Avatar
If I had waxed the paint and took care of it and all will it still have went? And why FWD? So if reverse gear and first gear were the same ratio, I would accelerate faster in reverse? Is this a cheaper way to build cars? Is Nissan cheap??????????
Old Jul 15, 2006 | 07:53 PM
  #53
kcidmil's Avatar
I believe the only thing actually done cheaply on the Max is the exhaust manifold studs. Nissan isn't cheap till you get into the 05 and later years where they have all sorts of problems. I can't wait to see what the new transmission is going to do.
The FWD was a system designed to give more cabin room. Eliminating the hump for the drive shaft.
Old Jul 15, 2006 | 08:54 PM
  #54
mod or sell?
um 95 and up went cheaper.
nothing comparing build quality on my I30 vs my VE. VE wins.
Old Jul 16, 2006 | 08:09 AM
  #55
kcidmil's Avatar
Problems with brand new ones, compared to the 4th gen, I'd take a 4th over the new. Of course, I'll do it even one better and just keep my 3rd. Though I agree, the problems did start when Nissan started it's venture with Renault. You saw all the well built cars disappearing.
Old Jul 17, 2006 | 02:56 PM
  #56
:bigbanstick:
put license plates under your rear wheels and pull e-brake.....heh.. new idea to teenage "drifting"
