fuel injector test?
Old Jul 4, 2006 | 12:08 PM
vansskaterfreek's Avatar
fuel injector test?
how do you check to see if your fuel injector is working correctly?? my stealth is running on 5 cylinders, and my plugs/wires/coils are all good..... so i think it is the injector..... i posted here because the stealth forum sucks, and i thought all injectors can be tested the same way.
Old Jul 4, 2006 | 12:51 PM
Josh's Avatar
Test the resistance on the injectors terminals, and see if it falls within the given range, I dunno what the specs are for dodge so you will have to look that up, i think for the max it must be between 10-14 ohms but i'm not sure.
Old Jul 4, 2006 | 02:20 PM
i pulled the plug out again, and while the plug out i cranked it once or twice, and i smell fuel in the cylinder.........so i have spark, and i have fuel.......hopefuly my timing belt didnt jump a tooth....anybody else have any input?
Old Jul 4, 2006 | 04:54 PM
Will's Avatar
Pull the injector plugs (the ones that are accessible) out WHILE the engine is running rough, and not the change in engine running condition. If you pull one plug and the rough running stays the same, that cylinder may be dead.
Another helpful but inconclusive option is pulling the injectors. A cylinder that is not getting sufficient gas (too lean) will be white.
Old Jul 4, 2006 | 05:09 PM
while i had the car running, i checked that stuff, thats how i realized it was the front center cylinder......now i am thinking it is a blown head gasket because it is puffing out white smoke....... tomorrow i will do a compression test, and it should help me out a little
Old Jul 11, 2006 | 12:32 PM
tomas hayden's Avatar
what are the compression numbers for cylinders??
Old Jul 11, 2006 | 02:01 PM
i think 160 is good...... just check all of your cylinders..... they should be all about the same.
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Forge277
Jun 13, 2016 09:26 PM
