Bad o2 sensor?
Bad o2 sensor?
Ok as you all probably know, I just replaced my knock sensor and a bad injector. I got the vacume leak fixed (turns out it was bad o rings on the fuel rail) Now everything runs good, but befor when I had the leak it triped some codes, one being o2 sensor. I drove the car around and the light went off. But now I have smoke comming from my tail pipe and it smells like raw gas. Any ideas?
Originally Posted by MyGreenMax94
Sounds like you still have a o ring leaking...
Originally Posted by probmxstyle
The o rings that where leaking whernt the ones on the injector. It was the ones that seals the fuel rail onto the intake. So they didnt actually have anything to do with gas. And i didnt touch any of the injectors, just the new one and i put new o rings on that one
You may have pinched the o ring when you installed the new injector into the rail....This happens alot....
Mike
I do have one more question. When installing the smaller o ring. the one on the bottom of the injector. Does it sit at the bottom of the hole that the injector sits in or does it get installed on tjhe injector?
