Window problem.
Old Jul 8, 2006 | 11:06 PM
colinod's Avatar
Window problem.
My passenger window wont roll down, won't roll up. No matter what switch i activate or whatever, I can't activate it. Even when I grab the window and force it up, I can't shut it. Is there a way to get it up. I don't even want to fix it, or make it usable for rolling down again, I just want it up.
Old Jul 9, 2006 | 05:34 AM
internetautomar's Avatar
mod or sell?
do the back windows work?
Old Jul 9, 2006 | 09:04 AM
Hectic's Avatar
if neither the master switch or passenger switch will work then it's probably your regulator all tangled, or less likely the motor is dead. remove the regulator and prop up the window with a correct length pvc pipe or slab of wood with a slit cut on the end for the window to rest in. or just replace the regulator while you're in there.
jmlee44
Oct 2, 2022 02:13 PM
Fbana41
Aug 29, 2016 12:18 PM
D Mason
Jun 21, 2016 04:43 AM
