'94 DOHC in a '93?
Old Jul 11, 2006 | 09:51 AM
Rungi's Avatar
'94 DOHC in a '93?
This at all possible? Bent a valve and mechanic doesn't want to do the valve job due to possible lower end problem developing. Jasper won't build one. Don't think I want to take chances with a used motor and I don't think the mechanic does either.
Nissan fixed the VTC problem in the '94 didn't they?
Search is giving me errors...
Old Jul 11, 2006 | 09:54 AM
Jeff92se's Avatar
I'm needing a caw
yes, it will work.......
Old Jul 11, 2006 | 10:30 AM
Rungi's Avatar
Awesome, would you know of any minor/major issues Jeff?
Thank you!
Old Jul 11, 2006 | 11:02 AM
Greeny's Avatar
¯\(°_o)/¯
[img]jeffypullingmotoroutofcliffyscar.jpg.[/img]
Old Jul 11, 2006 | 12:36 PM
Michael's Avatar
Back in a 3rd Gen.
Thank you!
VE is VE whether 92-94. The only difference is the auto doesnt have a variable intake so if you have a 5spd you will want to be sure and swap the upper intake with the variable one if you get an auto motor.
I think if you go JDM you will have a couple of differences but never really read any of those threads.
Its still a good idea to do all the little things while the motor is out of the car. Those things are...water pump, knock sensor, rebuild VTCs, replace exhaust studs, replace oil seals (front and rear) on the motor, axle seals on the trans, and pull the oil pan and reseal it (may not be needed but I did it anyway). you will easily spend $500 on parts and gaskets for all of that though.
Old Jul 11, 2006 | 03:24 PM
internetautomar's Avatar
mod or sell?
just so that you are aware, some places call early 95s 94s because of the early start of 95 production (think around febuary or march)
Old Jul 11, 2006 | 03:58 PM
Rungi's Avatar
Thanks guys... I'll keep you posted. Originally, Jasper/mechanic quoted $5k for the rebuild motor but Jasper called the mechanic back and said hell no! : Grrrrr, just do it! Wimps.. heh
Old Jul 11, 2006 | 04:54 PM
Cliff Clavin's Avatar
Way out West
To be honest, I would not spend anywhere near $5k to put a rebuilt engine into one of these cars.
I will sell you my entire car for that and I will include a set of snow tires, a set of stock wheels, a spare transmission and a trunk full of spare parts.
Usually a Japanese engine can be found in the neighborhood of $700-$1k. That's just for the engine. The JDM engine I bought had a 1-year, unlimited mile warranty on it. If you buy a junkyard engine, it probably won't have a warranty, but will usually be quite a bit less.
There is a thread in the stickies about JDM engine swaps. There are a few things that will need to be swapped over on a JDM and some things that would be very wise to replace (like a new water pump, manifold studs) even if you buy a junkyard engine.
Old Jul 11, 2006 | 09:37 PM
Rungi's Avatar
Thanks Cliff, I'll have a chat with my mechanic. I don't have the time or tools to do it myself. The 5k included warrenty that covered parts & labor.
Old Jul 12, 2006 | 09:48 PM
DigitalMaxima90's Avatar
I wish I could get a freaking ve30de. i like my sohc 160hp but i wish i had a 190hp dohc. that would b even more fun.
Old Jul 12, 2006 | 09:51 PM
evil pete's Avatar
Ahh I hear that dude, I would love another 30 hp, but apparentley they make more performance parts for the VG? Eh, idk,i don't have money for a swap anyway at the moment haha.
Old Jul 12, 2006 | 09:57 PM
but my dad wont even let me fix up my engine on my car, since its my 1st car he wants it to last. so if i did a engine swap it wont literally still be stock. with more power.
so i just want a paintjob, lower it, and get rim(17s). And, a VE swap
Old Jul 12, 2006 | 10:17 PM
evil pete's Avatar
Hmmm, he wont even let you put CAI? What fun is he? Haha, that is why I have both sets of keys to my car, that way my mom cant look where she shouldnt be
Old Jul 13, 2006 | 07:38 AM
mod or sell?
you're from murfreesboro TN?
kinda funny I just got an order for coil springs from there
Old Jul 14, 2006 | 07:08 PM
Rungi's Avatar
Ok, made up my mind. Car is going into my garage, after I make room. heh Rebuild! I love this car too much to part it out.
I'd like a list of parts, if you guys don't mind. Perhaps some high performance replacements here and there. Cams? What else there? Anyone know what I'd need to do "IF" I swapped out the Auto for a manual? Can I do the newer six speed? I may ditch the A/C equipment though. What about the ignition and those bloody coil packs? No way I can ditch those for 1 coil and SP wires eh?
Was there ever a V6 max that used standard plug wires? I'd guess not since they are deep in the top of the engine.
Parts I already know of that are going to get replaced.
EGR, knock, VTC's, waterpump, Underdrive pulley, seals, erm brain dead, can't think of anything else you guys have mentioned. Oh, the ECU and finish the exhaust.
Thanks for any suggestions.
Old Jul 14, 2006 | 07:46 PM
Alex_V
I think there are some cams out there, just look in the all motor forum.
Theres info in the stickies in this forum about the 5 speed swap. Its pretty easy Ive done it.
Id say keep the AC unless your going to lighten the entire car. 40lb isnt that much for alot more comfort at the touch of a button. But after driving a few cars with and some w/o Ill go for the AC every time unless its a track *****.
The coil packs definitly help performance. And there no easy way to get rid of them unless you went with something like a megasquirt ECU. Its fully tunable and $170-300 http://www.megasquirt.info/
add a fidanza alu flywheel and your set, if you do a manual conversion.
~Alex
Lilchikcadee
May 1, 2019 08:49 AM
londonflu
40
Sep 25, 2015 09:11 AM
tardrex
Sep 11, 2015 07:35 PM
VerzOphion
Aug 28, 2015 07:57 PM
Jeff92se
Dec 24, 2001 08:47 AM
