93 maxima
Old Jul 11, 2006 | 02:09 PM
tomas hayden's Avatar
93 maxima
hi guys'
i am new to this site .
i have a 93 maxima that has developed a miss.
i traced it down to the number 3 cylinder by pulling the spark plug wire while the enguine was at idle.
so i am going to check compression for that cylinder and also test injector.
is there any thing else to check?
and where is the ecu mounted ??
great site and thanks in advance..
Old Jul 11, 2006 | 02:13 PM
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by tomas hayden
hi guys'
Have you tried a tune up??
Check your original post about the location of the ecu..
Old Jul 11, 2006 | 03:34 PM
internetautomar's Avatar
mod or sell?
don't forget to pull the plugs and check their condition
Old Jul 11, 2006 | 04:06 PM
GRNMAXDMON's Avatar
pull the injector harness and c if has developed the green corrosion. if it did get an old tooth brush a car battery thats layin' around and dump the brush head into the battery acid and brush it onto the injectors and injector harness. let it dry up completely and reconnect the harness and start the car and c what happens. do the same procedure to the coolant temp. sensor and also crimp the female connectors a bit so that when u plug everything right back up it should be a tighter fit vs a loose fit.
Old Jul 11, 2006 | 04:16 PM
i have done a complete tune up.
that is plugs, wires, cap and button,pcv air and oil filter..
thanks.
also there is no corrosion in the wires or injector plugs..
i will check the temperture sending sensor
thanks
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
